PM sent.littlemo00 wrote: Wed Jul 23, 2025 1:23 am Would like to know if my drive can be flashed to read 4k.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: QJDL127144UC
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
littlemo00
That worked great. Thank you.
thejay
I'd also appreciate supportDrive Information
OS device name: H:
Revision: 3.10
Serial number: RGDL009413WL
PM sent.thejay wrote: Mon Aug 04, 2025 4:12 pmI'd also appreciate supportDrive Information
OS device name: H:
Revision: 3.10
SetzerPro
This seems to be a fairly popular drive. I have one as well, and I would appreciate support as well please.
Cheers!
Robert
Cheers!
Robert
Post your Makemkv info.SetzerPro wrote: Wed Aug 06, 2025 4:16 pm This seems to be a fairly popular drive. I have one as well, and I would appreciate support as well please.
Cheers!
Robert
SetzerPro
Oops! My bad!
Revision: 3.10
Serial number: RDDL075508UC
Revision: 3.10
PM sent.SetzerPro wrote: Thu Aug 07, 2025 5:38 am Oops! My bad!
Revision: 3.10
hemi1961
Coopervid,
If I have multiple drives(Mix of BDR-212DBK and BDR-212V), do I need to send the info for each, or will what you send for one work for them all?
Please post the Makemkv info for both. Just to make sure and play it safe.hemi1961 wrote: Sat Aug 09, 2025 8:48 am Coopervid,
hemi1961
Here is the info for the drives:Coopervid wrote: Sat Aug 09, 2025 5:35 pmPlease post the Makemkv info for both. Just to make sure and play it safe.hemi1961 wrote: Sat Aug 09, 2025 8:48 am Coopervid,
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ****
Firmware date: 2020-07-21
Highest AACS version: 25
Drive platform: RS8F01
Firmware version: 1.01/ID72
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ****
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
PM sent.hemi1961 wrote: Sun Aug 10, 2025 11:15 pmHere is the info for the drives:Coopervid wrote: Sat Aug 09, 2025 5:35 pmPlease post the Makemkv info for both. Just to make sure and play it safe.hemi1961 wrote: Sat Aug 09, 2025 8:48 am Coopervid,
Revision: 1.01
Serial number: ****
Revision: 1.02
Serial number: ****
K3ks3r
Hi, my Asus 5.25 BW-16D1HT is starting to have issues with some disks. I have found an old BDR-XD05 drive, is it possible to make it UHD compatible?
Help would be appreciated. Thanks
OS device name: I:
Revision: 3.10
Serial number: RGDL009194WL
Highest AACS version: 76
PM sent.K3ks3r wrote: Sun Aug 17, 2025 6:27 pm Hi, my Asus 5.25 BW-16D1HT is starting to have issues with some disks. I have found an old BDR-XD05 drive, is it possible to make it UHD compatible?
Help would be appreciated. ThanksCode: Select all
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: RGDL009194WL Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes![]()
GmanEst72
Wondering if anyone can help. A friend has just gave me a drive he didn't need any more, MakeMKV info below.
I think he my have flashed to the pioneer newest firmware showing 3.11, not sure if it can be done.
OS device name: H:
Revision: 3.11
Serial number: ****************
Firmware date: 2023-03-03
Highest AACS version: 77
Drive platform: Pioneer RS8232
Firmware version: ID34
OS device name: H:
Revision: 3.11
