Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
littlemo00 wrote: Wed Jul 23, 2025 1:23 am Would like to know if my drive can be flashed to read 4k.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: QJDL127144UC
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
PM sent.
littlemo00
Post by littlemo00 »
That worked great. Thank you.
thejay
Post by thejay »
OS device name: H:
Revision: 3.10
Serial number: RGDL009413WL
I'd also appreciate support
thejay wrote: Mon Aug 04, 2025 4:12 pm
OS device name: H:
Revision: 3.10
PM sent.
SetzerPro
Post by SetzerPro »
This seems to be a fairly popular drive. I have one as well, and I would appreciate support as well please.
Cheers!
Robert
SetzerPro wrote: Wed Aug 06, 2025 4:16 pm This seems to be a fairly popular drive. I have one as well, and I would appreciate support as well please.
Cheers!
Robert
Post your Makemkv info.
SetzerPro
Post by SetzerPro »
Oops! My bad!
Revision: 3.10
Serial number: RDDL075508UC
SetzerPro wrote: Thu Aug 07, 2025 5:38 am Oops! My bad!
Revision: 3.10
PM sent.
hemi1961
Post by hemi1961 »
Coopervid,
If I have multiple drives(Mix of BDR-212DBK and BDR-212V), do I need to send the info for each, or will what you send for one work for them all?
hemi1961 wrote: Sat Aug 09, 2025 8:48 am Coopervid,
Please post the Makemkv info for both. Just to make sure and play it safe.
hemi1961
Post by hemi1961 »
Coopervid wrote: Sat Aug 09, 2025 5:35 pm
Here is the info for the drives:
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ****
Firmware date: 2020-07-21
Highest AACS version: 25
Drive platform: RS8F01
Firmware version: 1.01/ID72
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ****
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
hemi1961 wrote: Sun Aug 10, 2025 11:15 pm
Revision: 1.01
Serial number: ****
Revision: 1.02
Serial number: ****
PM sent.
K3ks3r
Post by K3ks3r »
Hi, my Asus 5.25 BW-16D1HT is starting to have issues with some disks. I have found an old BDR-XD05 drive, is it possible to make it UHD compatible?
OS device name: I:
Revision: 3.10
Serial number: RGDL009194WL
Highest AACS version: 76
Help would be appreciated. Thanks :)
K3ks3r wrote: Sun Aug 17, 2025 6:27 pm Hi, my Asus 5.25 BW-16D1HT is starting to have issues with some disks. I have found an old BDR-XD05 drive, is it possible to make it UHD compatible?
OS device name: I:
Revision: 3.10
PM sent.
GmanEst72
Post by GmanEst72 »
Wondering if anyone can help. A friend has just gave me a drive he didn't need any more, MakeMKV info below.
I think he my have flashed to the pioneer newest firmware showing 3.11, not sure if it can be done.
OS device name: H:
Revision: 3.11
Serial number: ****************
Firmware date: 2023-03-03
Highest AACS version: 77
Drive platform: Pioneer RS8232
Firmware version: ID34
