BDR-XD08UMB-S LibreDrive Flash Help me!!!
Chepe607
Post by Chepe607 »
Hello I'm new at this patching stuff and drives, I bought this drive which the box says that is MDF July 2024, I was kind of disappointed, but when entering Make MKV is says the following data:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DGDL302265UC
Firmware date: 2022-12-27
Highest AACS version: 66
Drive platform: Pioneer RS9331
Firmware version: ID05
Disc Information
Label: BOHEMIAN_RHAPSODY
Timestamp: 2018-12-11 14:22:18
Protection: AACS2.0/C v66
Data capacity: 61.13 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Can I get someone to help me what to do next!?
When opening a disk it says
MakeMKV v1.18.1 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\mjose/.MakeMKV ...
Saved AACS dump file as C:\Users\mjose/.MakeMKV/MKB20_v66_Bohemian_Rhapsody_65F1.tgz
Re: BDR-XD08UMB-S LibreDrive Flash Help me!!!
The firmware is too new. You have to wait until Mike comes up with a solution for your drive.
th3scarfath3r
Post by th3scarfath3r »
I bought this drive as well, and have the same issue. Unfortunately LinusTechTips recommended it in the details section of this video: https://www.youtube.com/watch?v=GdQ5bClEgHg
I don't mind waiting for an option for this drive to come up. But I am hoping I can use this forum post as a way to try and stay informed for when it does become available for it to be UHD enabled.
zittrig
Post by zittrig »
Is the firmware 1.04 still not enabled? I was able to get one with version 1.02. LibreDrive enabled, works flawless. Does an update make sense or is it good as it is?
zittrig wrote: Fri Oct 09, 2026 10:16 am Is the firmware 1.04 still not enabled? I was able to get one with version 1.02. LibreDrive enabled, works flawless. Does an update make sense or is it good as it is?
works fine on 1.04
really on all versions it should now but if anyone wants a downgrade to 1.01 we can also do that see email below for that
zittrig
Post by zittrig »
Billycar11 wrote: Fri Oct 09, 2026 10:19 am
works fine on 1.04
Thanks for response Billy!
In the web can be found the differences between 1.02 and 1.04 is only an optimized writing process with different brands of discs. Any reason for an update especially for 4K ripping?
zittrig wrote: Fri Oct 09, 2026 10:47 am
For 4K ripping no reason to upgrade if your using makemkv
For other rippers downgrading is recommend
The few burns I did were fine on both versions it's was on a Sony bdrw 100
zittrig
Post by zittrig »
Ok, thank you!
