Post by dcoke22 » Sun Jul 20, 2025 12:59 pm
djdeity wrote: Sun Jul 20, 2025 4:44 am I'm having issues flashing my drive to handle UHD discs as well. Here's my drive according to MakeMKV 1.8.1 (paid):
Product: BD-RE BU40N
Revision: 1.01
Serial number:
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.01
I followed the instructions on the YouTube video, and here's where I got w/ PowerShell:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\WINDOWS\system32> c:
PS C:\WINDOWS\system32> cd..
PS C:\WINDOWS> cd..
PS C:\> cd C:\Program Files (x86)\MakeMKV
x86 : The term 'x86' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:22
+ cd C:\Program Files (x86)\MakeMKV
+ CategoryInfo : ObjectNotFound: (x86:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\> program files (x86)
At line:1 char:16
+ program files (x86)
PS C:\> cd "C:\Program Files (x86)\MakeMKV"
PS C:\Program Files (x86)\MakeMKV> makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System32\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
makemkvcon64.exe : The term 'makemkvcon64.exe' is not recognized as the name of a cmdlet, function, script file, or
operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:1
+ makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System3 ...
+ CategoryInfo : ObjectNotFound: (makemkvcon64.exe:String) [], CommandNotFoundException
Suggestion [3,General]: The command makemkvcon64.exe was not found, but does exist in the current location. Windows PowerShell does not load commands from the current location by default. If you trust this command, instead type: ".\makemkvcon64.exe". See "get-help about_Command_Precedence" for more details.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System32\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Drive "C:" not found
makemkvcon64.exe : The term 'makemkvcon64.exe' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the
At line:1 char:1
No matter what I did, PowerShell tells me the C: drive didn't exist when I tried to flash. I'm a bit of a noob myself, but I thought I followed everything perfectly. Appreciate your help.
When most people flash LG based drives like yours, they use the SDFtool Flasher and follow the instructions in the Ultimate UHD Drives Flashing Guide, which on your BU40N are "BU40N on any Firmware directly to > BU40N 1.03MK"
djdeity
Post by djdeity » Sun Jul 20, 2025 6:30 pm
I did try SDFtool Flasher first. When I tried to write the ".bin" file, it ran fine, but didn't update the drive.
Post by Billycar11 » Sun Jul 20, 2025 8:37 pm
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
Looks like your on a 32 but system trying to use 64 bit stuff
peterchan
Post by peterchan » Mon Jul 21, 2025 8:42 pm
May I ask if my 2nd UHD drive from buffalo BRUHD-PU3, flashable?
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: MOEN2BI0357
Firmware date: 2121-06-21 13:30
Highest AACS version: 17
THank you very much
wow001
Post by wow001 » Tue Jul 22, 2025 12:22 am
I am trying to downgrade a slim LG BU40N from version 1.04 to 1.03 using a mac.
Drive details:
LG BU40N before.png (376.13 KiB) Viewed 18733 times
I used the method laid out on page 1
copied the two files "sdf.bin" and "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin" to the /temp folder.
Opened the terminal and followed the instructions:
terminal window.png (381.4 KiB) Viewed 18733 times
The terminal window shows that the flash was "Done successfully" but opening the makeMKV application show the drive is still on version 1.04.
LG BU40N after.png (386.26 KiB) Viewed 18733 times
Does any body know what i have done wrong ?
djdeity
Post by djdeity » Tue Jul 22, 2025 12:58 am
I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Billycar11 wrote: Sun Jul 20, 2025 8:37 pm
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
Post by d00zah » Tue Jul 22, 2025 1:07 am
wow001 wrote: Tue Jul 22, 2025 12:22 am I am trying to downgrade a slim LG BU40N from version 1.04 to 1.03 using a mac.
Drive details:
v1.04 is encrypted FW. Change 'main' to 'enc' in your command.
Post by MartyMcNuts » Tue Jul 22, 2025 3:23 am
djdeity wrote: Tue Jul 22, 2025 12:58 am I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
Your firmware is not encrypted so change enc to main in your command.
wow001
Post by wow001 » Tue Jul 22, 2025 8:45 am
Thank you d00zah "v1.04 is encrypted FW. Change 'main' to 'enc' in your command." worked
./makemkvcon f -d '/IOBDServices/8ACC6D28' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
djdeity
Post by djdeity » Tue Jul 22, 2025 11:32 pm
MartyMcNuts wrote: Tue Jul 22, 2025 3:23 am
Thanks for the response, but now I'm having another problem when I use Command Prompt - see below (NOTE: I moved the .bin file to a separate folder on my D: drive):
C:\Program Files (x86)\MakeMKV>.\makemkvcon64.exe f --all-yes -d C: rawflash main -i D:\MakeMKV\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
I can't understand why it's coming back saying the C: drive isn't found.
Post by MartyMcNuts » Wed Jul 23, 2025 12:24 am
djdeity wrote: Tue Jul 22, 2025 11:32 pm
C: is not your optical drive. Change C: to your optical drive letter.
Also, don't use BU40N 1.04-MK. It is crap. Use either BU40N 1.03-MK or BU40N 1.00 if you use other software besides MakeMKV.
djdeity
Post by djdeity » Wed Jul 23, 2025 2:12 am
MartyMcNuts wrote: Wed Jul 23, 2025 12:24 am
Thanks for the recommendation on 1.03 - I used that .bin file. I reworked the command, and the flash worked properly. I'm ripping my 4K disc right now to make sure it works. Appreciate your help!
CBannana
Post by CBannana » Fri Jul 25, 2025 6:59 pm
I'm pretty new to all of this and having an issue with the firmwear.
I figure I need to get the exact firmwear revision but I cant see to find mine anywhere.
I am using a LG BP60NB10 revision 1.01. In the guide and elsewhere I can see versions 1.00 and 1.02 but not 1.01 to download.
Does anyone have access to that for me to use to flash my drive?
Post by Billycar11 » Fri Jul 25, 2025 8:01 pm
CBannana wrote: Fri Jul 25, 2025 6:59 pm I'm pretty new to all of this and having an issue with the firmwear.
you dont need it thats why it says on any fw
CBannana
Post by CBannana » Sat Jul 26, 2025 1:23 am
Billycar11 wrote: Fri Jul 25, 2025 8:01 pm
Thanks I appreciate the help! I'm a little stressed about bricking the drive, pretty hard to find cheap.
so am I right in thinking I can flash it safely with: "HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin"?
I really do appreciate the help!
