When most people flash LG based drives like yours, they use the SDFtool Flasher and follow the instructions in the Ultimate UHD Drives Flashing Guide, which on your BU40N are "BU40N on any Firmware directly to > BU40N 1.03MK"djdeity wrote: Sun Jul 20, 2025 4:44 am I'm having issues flashing my drive to handle UHD discs as well. Here's my drive according to MakeMKV 1.8.1 (paid):
Product: BD-RE BU40N
Revision: 1.01
Serial number:
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.01
I followed the instructions on the YouTube video, and here's where I got w/ PowerShell:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\WINDOWS\system32> c:
PS C:\WINDOWS\system32> cd..
PS C:\WINDOWS> cd..
PS C:\> cd C:\Program Files (x86)\MakeMKV
x86 : The term 'x86' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:22
+ cd C:\Program Files (x86)\MakeMKV
+ CategoryInfo : ObjectNotFound: (x86:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\> program files (x86)
At line:1 char:16
+ program files (x86)
PS C:\> cd "C:\Program Files (x86)\MakeMKV"
PS C:\Program Files (x86)\MakeMKV> makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System32\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
makemkvcon64.exe : The term 'makemkvcon64.exe' is not recognized as the name of a cmdlet, function, script file, or
operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:1
+ makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System3 ...
+ CategoryInfo : ObjectNotFound: (makemkvcon64.exe:String) [], CommandNotFoundException
Suggestion [3,General]: The command makemkvcon64.exe was not found, but does exist in the current location. Windows PowerShell does not load commands from the current location by default. If you trust this command, instead type: ".\makemkvcon64.exe". See "get-help about_Command_Precedence" for more details.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d C: rawflash enc -i C:\Windows\System32\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Drive "C:" not found
makemkvcon64.exe : The term 'makemkvcon64.exe' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the
At line:1 char:1
No matter what I did, PowerShell tells me the C: drive didn't exist when I tried to flash. I'm a bit of a noob myself, but I thought I followed everything perfectly. Appreciate your help.
djdeity
I did try SDFtool Flasher first. When I tried to write the ".bin" file, it ran fine, but didn't update the drive.
Looks like your on a 32 but system trying to use 64 bit stuffdjdeity wrote: Sun Jul 20, 2025 4:44 am I'm having issues flashing my drive to handle UHD discs as well. Here's my drive according to MakeMKV 1.8.1 (paid):
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
peterchan
May I ask if my 2nd UHD drive from buffalo BRUHD-PU3, flashable?
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: MOEN2BI0357
Firmware date: 2121-06-21 13:30
Highest AACS version: 17
THank you very much
Revision: BU14
THank you very much
wow001
I am trying to downgrade a slim LG BU40N from version 1.04 to 1.03 using a mac.
Drive details: I used the method laid out on page 1
copied the two files "sdf.bin" and "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin" to the /temp folder.
Opened the terminal and followed the instructions: The terminal window shows that the flash was "Done successfully" but opening the makeMKV application show the drive is still on version 1.04.
Does any body know what i have done wrong ?
djdeity
I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Billycar11 wrote: Sun Jul 20, 2025 8:37 pmLooks like your on a 32 but system trying to use 64 bit stuffdjdeity wrote: Sun Jul 20, 2025 4:44 am I'm having issues flashing my drive to handle UHD discs as well. Here's my drive according to MakeMKV 1.8.1 (paid):
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
v1.04 is encrypted FW. Change 'main' to 'enc' in your command.wow001 wrote: Tue Jul 22, 2025 12:22 am I am trying to downgrade a slim LG BU40N from version 1.04 to 1.03 using a mac.
Drive details:
Your firmware is not encrypted so change enc to main in your command.djdeity wrote: Tue Jul 22, 2025 12:58 am I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Revision: 1.01
Serial number:
Windows PowerShell
PS C:\WINDOWS> cd..
At line:1 char:22
At line:1 char:16
again.
At line:1 char:1
At line:1 char:1
wow001
Thank you d00zah "v1.04 is encrypted FW. Change 'main' to 'enc' in your command." worked
./makemkvcon f -d '/IOBDServices/8ACC6D28' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
djdeity
MartyMcNuts wrote: Tue Jul 22, 2025 3:23 amYour firmware is not encrypted so change enc to main in your command.djdeity wrote: Tue Jul 22, 2025 12:58 am I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Thanks for the response, but now I'm having another problem when I use Command Prompt - see below (NOTE: I moved the .bin file to a separate folder on my D: drive):
C:\Program Files (x86)\MakeMKV>.\makemkvcon64.exe f --all-yes -d C: rawflash main -i D:\MakeMKV\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
I can't understand why it's coming back saying the C: drive isn't found.
C: is not your optical drive. Change C: to your optical drive letter.djdeity wrote: Tue Jul 22, 2025 11:32 pmMartyMcNuts wrote: Tue Jul 22, 2025 3:23 amYour firmware is not encrypted so change enc to main in your command.djdeity wrote: Tue Jul 22, 2025 12:58 am I'm more than confident that my CPU is 64 bit. Are you saying this because of the folder I put the .bin file in - I can move it to a different folder. So how can I fix the issue?
Also, don't use BU40N 1.04-MK. It is crap. Use either BU40N 1.03-MK or BU40N 1.00 if you use other software besides MakeMKV.
djdeity
Thanks for the recommendation on 1.03 - I used that .bin file. I reworked the command, and the flash worked properly. I'm ripping my 4K disc right now to make sure it works. Appreciate your help!MartyMcNuts wrote: Wed Jul 23, 2025 12:24 amC: is not your optical drive. Change C: to your optical drive letter.djdeity wrote: Tue Jul 22, 2025 11:32 pmMartyMcNuts wrote: Tue Jul 22, 2025 3:23 am
CBannana
I'm pretty new to all of this and having an issue with the firmwear.
I figure I need to get the exact firmwear revision but I cant see to find mine anywhere.
I am using a LG BP60NB10 revision 1.01. In the guide and elsewhere I can see versions 1.00 and 1.02 but not 1.01 to download.
Does anyone have access to that for me to use to flash my drive?
you dont need it thats why it says on any fwCBannana wrote: Fri Jul 25, 2025 6:59 pm I'm pretty new to all of this and having an issue with the firmwear.
CBannana
Thanks I appreciate the help! I'm a little stressed about bricking the drive, pretty hard to find cheap.Billycar11 wrote: Fri Jul 25, 2025 8:01 pmyou dont need it thats why it says on any fwCBannana wrote: Fri Jul 25, 2025 6:59 pm I'm pretty new to all of this and having an issue with the firmwear.
so am I right in thinking I can flash it safely with: "HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin"?
I really do appreciate the help!
