Asus BW-16D1X-U
HSamwel
Re: Asus BW-16D1X-U
Post by HSamwel »
Coopervid wrote:
Sun Jul 06, 2025 12:05 pm
Such a thing has never been reported before. Is this a drive in an USB enclosure? If yes you need to remove power AND USB. Otherwise the drive electronics is still powered by the USB connection.
These errors can also originate if the drive doesn't get enough power. Maybe with the new firmware it needs more power.
If it’s the same I have, it’s in an USB enclosure. It uses its own power and not from the USB.
You can find it on the ASUS site.
Re: Asus BW-16D1X-U
For a successful flash power needs to be removed completely. Both power supply plus USB. Otherwise the electronics is kept alive and doesn't reset the drive.
BiBiNaToR
Re: Asus BW-16D1X-U
Post by BiBiNaToR »
Salut Cooper,
y a-t-il encore un flash pour la version E113 ?
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : ASUS
Produit : BW-16D1X-U
Révision : E113
Numéro de série :
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 81
Firmware version: ID76
Re: Asus BW-16D1X-U
BiBiNaToR wrote:
Fri Jul 18, 2025 1:04 pm
Salut Cooper,
Fabricant : ASUS
Révision : E113
Numéro de série :
PM sent.
BiBiNaToR
Re: Asus BW-16D1X-U
Post by BiBiNaToR »
Coopervid wrote:
Fri Jul 18, 2025 1:59 pm
Salut Cooper,
Fabricant : ASUS
Révision : E113
Numéro de série :
PM sent.
thank you Cooper
BiBiNaToR
Re: Asus BW-16D1X-U
Post by BiBiNaToR »
cooper, on the other hand, how do I return to the original firmware if there is a problem, thank you
Re: Asus BW-16D1X-U
BiBiNaToR wrote:
Fri Jul 18, 2025 2:39 pm
No risk, no fun.
Ducreux
Re: Asus BW-16D1X-U
Post by Ducreux »
Hey all,
Could someone help out with a flash to enable LibreDrive on my new BW-16D1X-U please?
MakeMKV output or the drive is below:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 81
Also, just to confirm - I am right in thinking that LibreDrive flashing removes the Blu Ray region lock as well as unlocking the UHD ripping functionality?
Thanks in advance :)
Re: Asus BW-16D1X-U
Ducreux wrote:
Sat Jul 19, 2025 4:10 pm
Hey all,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Ducreux
Re: Asus BW-16D1X-U
Post by Ducreux »
Thank you, I'll have to dig out my old Windows laptop to flash but that's no big deal! I'm mostly MacOS these days :)
BiBiNaToR
Re: Asus BW-16D1X-U
Post by BiBiNaToR »
hello how to reflash a drive? I have a file.tar so how to reset the original firmware thank you
Re: Asus BW-16D1X-U
BiBiNaToR wrote:
Sun Jul 20, 2025 7:18 pm
Wndows only. You were told so.
Re: Asus BW-16D1X-U
...and don't shit your pants. The crossflash works perfectly. No need to flash back. And we don't have the ASUS firmware to do so.
