Brazil Criterion Collection 4K
markthemoviefan
#1 Post by markthemoviefan » Fri Jul 18, 2025 11:09 pm
Just got the 4K Criterion Collection version of Terry Gilliam's Brazil and can't rip it. Dump file is attached. Any help is appreciated.
MKB20_v77_BRAZIL_558E.tgz
(3.33 MiB) Downloaded 210 times
keydb_helper
Re: Brazil Criterion Collection 4K
#2 Post by keydb_helper » Sat Jul 19, 2025 3:16 am
markthemoviefan wrote: Fri Jul 18, 2025 11:09 pm Just got the 4K Criterion Collection version of Terry Gilliam's Brazil and can't rip it. Dump file is attached. Any help is appreciated.
Hey Mark, if you haven't already I'm sure the MakeMKV team would appreciate it if you could email that disc dump file to them at svq@makemkv.com
Until your variant of Brazil is natively supported by MakeMKV, you can configure MakeMKV to utilise the public keydb as your disc has been supported since May 30. You can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
markthemoviefan
#3 Post by markthemoviefan » Sat Jul 19, 2025 1:28 pm
Thanks! I just sent off the email with the dump file, which is now moot...
After following your suggestion I pulled the keydb.cfg and got it running on my machine and now the files are extracting!
Thanks for your help!
Mark
keydb_helper
#4 Post by keydb_helper » Sun Jul 20, 2025 3:55 am
markthemoviefan wrote: Sat Jul 19, 2025 1:28 pm Thanks! I just sent off the email with the dump file, which is now moot...
Mark
No problem, I'm glad to hear you were able to get it setup. By emailing the disc dump file you've also assisted the MakeMKV team to natively support your disc, so I'm sure that will help other users in the future.
