ikthal
#16
Post
by ikthal » Thu Aug 15, 2024 2:53 pm
I'm getting some circular dependency errors as of yesterday. Anyone have any ideas? Debian Bookworm, no issues until yesterday:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libavcodec-extra59 : Conflicts: libavcodec59
libmakemkv1 : Depends: libavcodec59 (= 7:5.1.5-0+deb12u1)
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
If I try to resolve by installing the -extra59 variant, the error stays the same.
mathias
#17
Post
by mathias » Fri Aug 16, 2024 12:03 am
ikthal wrote: Thu Aug 15, 2024 2:53 pm
A
security update for ffmpeg was released, which will require a rebuild of makemkv because it uses a private function call from ffmpeg:
prahal wrote: Wed Apr 03, 2024 12:43 pm
Seems the only way out is to get rid of the private function call from libmakemkv1:
libffabi/src/ffabi.c: err = avpriv_mpegaudio_decode_header(&s, hdr);
libffabi/src/mpegaudiodecheader.h:int avpriv_mpegaudio_decode_header(MPADecodeHeader *s, uint32_t header);
(the "avpriv_mpegaudio_decode_header(&s, hdr);" call is in libffabi/src/ffabi.c in ffm_mpa_decode_header)
prahal
#18
Post
by prahal » Fri Aug 16, 2024 1:14 pm
Should I report the issue that makemkv uses a private call somewhere else than this forum ?
A hack is to build libmakemkv1 without this avpriv_mpegaudio_decode_header call, bit I am afraid makemkvconv might misbehave randomly.
Maybe the private ffmpeg function code could be copied to libmakemkv1 to fix this issue ?
-dag-
#19
Post
by -dag- » Mon Dec 02, 2024 1:26 am
I have not been able to install the testing packages for some time:
$ sudo aptitude install makemkvcon
The following NEW packages will be installed:
ccextractor{a} libdriveio0{a} libgpac12t64{a} makemkvcon{b}
0 packages upgraded, 4 newly installed, 0 to remove and 3 not upgraded.
Need to get 10.2 MB of archives. After unpacking 21.9 MB will be used.
makemkvcon : Depends: libmakemkv1 (>= 1.17.7) but it is not installable
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) makemkvcon [Not Installed]
$ sudo aptitude install libmakemkv1
libmakemkv1{b}
0 packages upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 124 kB of archives. After unpacking 665 kB will be used.
libmakemkv1 : Depends: libavcodec61 (= 7:7.1-3) but 10:7.1-dmo2+b1 is installed
1) libmakemkv1 [Not Installed]
mathias
#20
Post
by mathias » Tue Dec 03, 2024 2:43 pm
It looks like you have the
deb-multimedia repo enabled, which is pulling in a different compiled package of ffmpeg. Because makemkv compiles against an internal private ffmpeg function, apt tries to install the version of libavcodec61 from Debian's official repo, but that conflicts with the one provided by deb-multimedia.
Depending on your
apt priority pinning, you might be able to uninstall deb-multimedia's version of ffmpeg packages, then install makemkv.
-dag- wrote: Mon Dec 02, 2024 1:26 am
-dag-
#21
Post
by -dag- » Thu Dec 05, 2024 3:45 am
mathias wrote: Tue Dec 03, 2024 2:43 pm
Depending on your
I remove deb-multimedia and tried to clean things up as best as I could. Unfortunately it didn't help much:
libavutil59{a} libmakemkv1{b} libvdpau-va-gl1{a} libvdpau1{a} mesa-vdpau-drivers{a} vdpau-driver-all{a}
0 packages upgraded, 6 newly installed, 0 to remove and 70 not upgraded.
Need to get 124 kB/659 kB of archives. After unpacking 2,394 kB will be used.
libmakemkv1 : Depends: libavcodec61 (= 7:7.1-3) but it is not going to be installed
$ sudo aptitude install libavcodec61=7:7.1-3
libavcodec61{b} libavutil59{a} libcodec2-1.2{a} libshine3{a} libsoxr0{a} libswresample5{a} libvdpau-va-gl1{a} libvdpau1{a} libxvidcore4{a}
0 packages upgraded, 11 newly installed, 0 to remove and 70 not upgraded.
Need to get 14.1 MB/15.0 MB of archives. After unpacking 36.9 MB will be used.
libavcodec61 : Depends: libavutil59 (= 7:7.1-3) but 10:7.1-dmo2+b1 is to be installed
1) libavcodec61 [Not Installed]
$ sudo aptitude why-not libavcodec61=7:7.1-3
E: No package named "libavcodec61=7:7.1-3" exists.
I don't know if it's allowed to use version specifiers for why-not so the latter might be a red herring. But it seems the version needed might not be available?
Somewhat Reticent
#22
Post
by Somewhat Reticent » Sat Dec 07, 2024 6:31 am
MakeMKV (1.17.7) works on a live DebIan-Bookworm-based system*
libmmbd0 was listed but not installed - added ("recommends")
applied MakeMKV preference option for Integration - so VLC plays (and hopefully handbrake)
Also needed libbluray-bdj for menu java
( wonder if mpv/SMplayer … better subtitle background support than I get with VLC … ?)<hr>* until it gets an update to version 1.17.8, then it's back to libc version conflict (wants version 2.33/2.34, has 2.31).
prahal
#23
Post
by prahal » Wed Feb 05, 2025 9:55 pm
I made a debian patch to bring the private function call code into the makemkv library (and thus avoid debian package build tool dh_shlibs from setting a very tight versioned dependency.
https://salsa.debian.org/BenTheTechGuy/ ... requests/1
I believe it is good for upstream makemkv too. But let's try it in Debian first.
prahal on Mon May 05, 2025 12:37 am, edited 1 time in total.
Huehnchen_gott
#24
Post
by Huehnchen_gott » Wed Feb 26, 2025 10:34 pm
Hi, Im having trouble installing on Debian Bookworm due to missing dependencies. The repo seems to serve the backports (?) version of libdriveio0, which makemkv is not satisfied with. Anyone know how to fix this or do I need to wait for the packages to be upgraded?
-dag-
#25
Post
by -dag- » Sun Jul 20, 2025 3:03 am
apt.benthetechguy.net appears to be down and has been for several days. Is this the end?
BenTheTechGuy
#26
Post
by BenTheTechGuy » Thu Jan 08, 2026 5:58 am
Sorry for not responding to everyone's questions/concerns/PRs for a while there, I am still very busy these days.
To solve some of the intermittent hosting issues, I am moving my apt repo to
https://people.debian.org/~bjw/apt. The old link will still work as it just redirects to the new place. Thank you to everyone using my package!
prahal
#27
Post
by prahal » Thu Jan 08, 2026 4:28 pm
BenTheTechGuy wrote: Thu Jan 08, 2026 5:58 am
Note to users that I closed my salsa.debian.org PR about fixing ffmpeg tight versioning because it is fixed in upstream and package since version 1.18.2.
