Unable to start Cannot find shared library.
jmgibson1981
Post by jmgibson1981 »
I compiled both oss and the bin (edited makefile manually) to go to /opt/makemkv.
./configure --prefix /opt/makemkv
PREFIX=/opt/makemkv
respectively...
I've never had trouble doing this in the past but today when I try to run makemkv i get this terminal output.
/opt/makemkv/bin/makemkvcon: error while loading shared libraries: libmakemkv.so.1: cannot open shared object file: No such file or directory
I know the file is there.
$ find /opt/ -name '*libmake*'
/opt/makemkv/lib/libmakemkv.so.1
I'm lost. I like to put compiled stuff into a given folder so I don't need to worry about make uninstall or anything. i can just dump the whole directory and move on with my life.
My system.
$ sudo inxi -Fz
System:
  Kernel: 5.16.0-0.bpo.4-amd64 x86_64 bits: 64 Console: tty 0
  Distro: Debian GNU/Linux 11 (bullseye)
Machine:
  Type: Desktop System: NCSTECH product: CT1-A402 v: N/A serial: <filter>
  Mobo: ASUSTeK model: P8H61-M LE/CSM v: Rev x.0x serial: <filter>
  BIOS: American Megatrends v: 4501 date: 05/10/2013
CPU:
  Info: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
  L2 cache: 8 MiB
  Speed: 1596 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1596 2: 1596
  3: 1596 4: 1596 5: 1596 6: 1596 7: 1612 8: 1637
# edit #
My PATH as well for reference.
$ echo $PATH
/home/jason/bin:/opt/makemkv/bin:/opt/kodimatrix/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/snap/bin
bib1963
Re: Unable to start Cannot find shared library.
Post by bib1963 »
Late... but...
Run the following 2 commands as root, then retry...
echo "/opt/makemkv/lib" > /etc/ld.so.conf.d/makemkv.conf
ldconfig
sirgatez
Post by sirgatez »
Another important note. If you install makemkvcon in a different directory than makemkv, it will fail to start as it expects the executable to be in the same folder.
So I did:
makemkv-bin-1.18.1:
Update Makefile: PREFIX=/opt/makemkvcon
make
sudo make install
makemkv-bin-1.18.1:
./configure --prefox=/opt/makemkv
make
sudo make install
Finally, fix things up by adding the library path, and executable path.
echo 'PATH="/opt/makemkv/bin:/opt/makemkvcon/bin:$PATH"' > /etc/profile.d/makemkv.sh
sudo chmod +x /etc/profile.d/makemkv.sh
sudo ln -s /opt/makemkvcon/bin/makemkvcon /opt/makemkv/bin/makemkvcon
