Dump for First slam dunk and Decision to leave.
Both have been released recently in Korea.
Dump Summited for First Slam dunk and Decision to Leave
lkh126
keydb_helper
Re: Dump Summited for First Slam dunk and Decision to Leave
If you'd like to see MakeMKV support those discs you'll need to email the dump files to svq@makemkv.comlkh126 wrote: Sat Jul 19, 2025 9:00 am Dump for First slam dunk and Decision to leave.
Your particular variant of The First Slam Dunk is already supported by the public keydb. If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Because your disc dumps were created with a Pioneer drive the dump files can't be used to add support for Decision to Leave to the public keydb. If you happen to have a non-Pioneer LG/Asus drive feel free to create a new dump and post a link to the forum.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
