Godfather Trilogy - Coppala Restoration
Jsbulger
Post by Jsbulger » Tue Mar 18, 2025 4:08 pm
Having an issue with just DISC 1. I was able to get Disc 2 & 3, but Disc 1 errors out every time. I searched the forum for the hash check error, but that just says I have a bad Driver, which I know I do not, since it is working for a bunch of other BDs, just not this one disc. I have attached a TXT of the output from the MakeMKV application.
Godfather Part 1 errors.txt
(78.7 KiB) Downloaded 715 times
Re: Godfather Trilogy - Coppala Restoration
Post by Woodstock » Tue Mar 18, 2025 4:42 pm
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 6167451648, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00000.m2ts' (title #-) , future messages will be printed only to log file
Failed to save title 0 to file C:/Users/jared/Downloads/MKVs/The Godfather_t00.mkv
Encountered 243 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
There is a "bad spot" on this disk that your drive can't read easily, and, in at least one case, at all. Cleaning the disk may help.
I'd be suspicious that all the read problems were at a large offset from the beginning of the disk. There are places where the disk transitions between layers, which can be sensitive to dirt/contamination.
nwest15
Post by nwest15 » Sat Jul 19, 2025 5:26 am
Where you able to find a solution? I am having the same issue.
Jsbulger
Post by Jsbulger » Sat Jul 19, 2025 1:51 pm
I waited a few months, tried again and it just worked. I'm not sure exactly what caused it to finally work.
bigben
Post by bigben » Fri Jan 02, 2026 7:36 pm
I'm getting the same issue. Brand new Blu-ray, still had the plastic around the case before I loaded it into the drive. The discs for Part 2 and 3 worked fine. I can play Part 1 on my PS4 just fine. I've tried cleaning the drive and reading it on both Mac and Windows, but the issue persists.
These two errors over and over in the logs:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '24158797824'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '24158797824'
MakeMKV v1.18.2 darwin(arm64-release)
Apple M1 chip
macOS Sequoia 15.7.3
LG BP50NB40 NB52 drive
OS device name: /dev/rdisk5
Current profile: DVD-ROM
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK0CPALF3241
Firmware date: 2121-07-08 16:03
Highest AACS version: 50
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Unrestricted read speed: Possible (with patched firm
bigben
Post by bigben » Tue Jan 06, 2026 9:11 pm
Tried ripping the disc for Part 1 again today after wiping off the disc with a microfiber cloth again and this time it finally worked. The disc looked just as clean this time as it did the other time after I tried cleaning it so not sure if there was just something on it I couldn't see or what. Same drive, same firmware, same OS version, same version of MakeMKV.
