BDR 212V UHD Guide
zaybdr
Re: BDR 212V UHD Guide
Post by zaybdr »
Thank you.
By the way, when I checked the Pioneer website, I found that the firmware for the BDR-211M is 1.5x (1.51, 1.52, 1.53...), but the BDR-211M I have is 1.02. Do you know why this is?
Here you see that they started with 1.02 and then switched to 1.5x.
https://www.cdrinfo.pl/hardware/806-Pioneer-BDR-S11J-X
The 211 is the OEM version of S11 w/o software.
zaybdr
Post by zaybdr »
thanks for the information
billem
Post by billem »
Hate to be a bother, but seeing if you can help out.
billem wrote:
Mon Jul 07, 2025 10:06 pm
Yet another request if you would be so kind.
OS device name: /dev/rdisk10
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: [removed]
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
billem wrote:
Mon Jul 14, 2025 3:17 am
Revision: 1.02
PM sent.
jbmkvhd
Post by jbmkvhd »
Hello - Please let me know if this Pioneer BDR-212V can be enabled to get UHD. - Thanks for the help!
Revision: 1.02
jbmkvhd wrote:
Thu Jul 17, 2025 6:18 pm
Revision: 1.02
PM sent.
yellowstarmonkey
Post by yellowstarmonkey »
Hi, I purchased a Pioneer BDR-212V and need help to have it enabled for reading UHD. This is the info from makemkv. Thanks.
Revision: 1.02
Serial number: [ removed ]
Highest AACS version: 68
yellowstarmonkey wrote:
Fri Jul 18, 2025 4:59 am
Revision: 1.02
PM sent.
sweetlyBear
Post by sweetlyBear »
Hi, I purchased a Pioneer BDR-212V can you help me enable it for reading UHD. This is the info from makemkv. I have a Windows machine if that's perferable to linux. Thanks!
OS device name: /dev/sr0
Revision: 1.02
Serial number:
sweetlyBear wrote:
Sat Jul 19, 2025 3:39 am
Revision: 1.02
Serial number:
windows only for flashing
send me that drive info from windows to the email below for the flasher
Semi-Noob
Post by Semi-Noob »
Hi everyone,
I'll start by apologizing as I'm sure this has been asked a million times before.
I brought an ASUS BW-16D1H-U recently as I have a stack of old DVD's & blu-rays that I want rip so I can watch them on the Zidoo player I just brought but being a basic noob (I grew up when VHS was a thing) I didn't realize that the drive platform played a big part in the ripping of 4K UHD disks.
Is there a way of flashing this drive to make it compatible so I can rip 4K movies? Drive specs attached below
If anyone can help me out I'd really appreciate it.
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 16
Drive platform: RS8F00
Firmware version: E116/ID71
Semi-Noob wrote:
Sat Jul 19, 2025 4:31 am
Hi everyone,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent. You need a Windows PC or a good VM like VMWare.
