MakeMKV hangs/freezes when attempting to read disc
seamus
Re: MakeMKV hangs/freezes when attempting to read disc
#16 Post by seamus » Fri Jul 18, 2025 4:54 am
MartyMcNuts wrote: Wed Jul 16, 2025 6:25 am
Although MakeMKV can rip DVD discs, it is not the best software for doing so. There are plenty of other software applications that are better at ripping DVD discs. MakeMKV is the best when it comes to BD/UHD ripping though!!
This proclamation is news to me, so I'd like to get some details! I'm new at this, but have now ripped over 700 DVDs and BDs in the past 3 weeks. In general I've noticed that MakeMKV seems to struggle more frequently with DVDs than with BDs, and it's failed completely on about 10 DVDs. I initially used Handbrake, but concluded that sucked b/c it required me to re-encode everything, resulting in "Generation Loss".
So... can you provide some recommendations for a few of the "plentiful options" for ripping DVDs??
#17 Post by MartyMcNuts » Fri Jul 18, 2025 6:53 am
seamus wrote: Fri Jul 18, 2025 4:54 am
Mind you, I have not even looked at a DVD since 2007 as they are such poor quality but before BD, I mainly used DVD Shrink and DVD Decrypter to rip DVD's. There's also DVDFab, WinX DVD Ripper, 1Click DVD Copy among others...
francocho
#18 Post by francocho » Fri Jul 18, 2025 11:01 pm
MartyMcNuts wrote: Fri Jul 18, 2025 6:53 am
So you haven't burned a DVD in almost 20 years yet you confidently claim that there are plenty of better options than MakeMKV before proceeding to list a bunch of abandonware and overly commercialized crap. This sounds a lot like your unsolicited opinion on Macs: worthless.
#19 Post by MartyMcNuts » Sat Jul 19, 2025 12:35 am
francocho wrote: Fri Jul 18, 2025 11:01 pm
That's alright. No one asked for your opinion either!
seamus
#20 Post by seamus » Sat Jul 19, 2025 10:18 pm
I guess I should have qualified my request for information... instead of "plentiful options", I probably should have said "plentiful options that are maintained, and yield better results than MakeMKV".
I've gotta' agree w/ francocho here... the "plentiful options" you've listed look like dogs to me... I wish you hadn't gotten my hopes up. If you've not ripped a DVD in 20 years, most would question the veracity of your recommendations, eh?
seamus
#21 Post by seamus » Sat Jul 19, 2025 10:52 pm
dcoke22 wrote: Wed Jul 16, 2025 3:13 pm Do you have a different drive you can try? Since it is a DVD, just about any drive will work, even an old Apple SuperDrive if you've got one collecting dust in a closet.
FWIW: My experience (recent and limited as it may be) suggests that the drive DOES make a difference - on DVDs and BDs.
I've been at this about 3 weeks, and have ripped approx 700 DVDs + BDs. I estimate that approx 75-100 have been BDs; the balance are DVDs. I've used 3 drives: a Pioneer, an Asus, and since yesterday a Buffalo. Until today, my results have been as follows:
  • Zero BD failures
  • Eight (8) DVD failures
I tried each of the 8 DVD failures in the new Buffalo drive. The Buffalo produced a "good" mkv file from 4 of the 8 DVD failures. All 8 failures had been thoroughly cleaned, and failed previously in both the Asus and the Pioneer drives.
I've returned the Pioneer drive to the merchant b/c it seemed flimsy and definitely slower than the Asus. Also, I inadvertently upgraded the firmware on the Pioneer... but have since learned that the "LibreDrive" firmware only works with Windows?! (Suggesting it's not actually firmware at all.)
Final data point: I had my first BD failure today using the Buffalo drive! Afterwards, I moved the failed BD from the Buffalo to the Asus (no cleaning as it was a new BD), and the Asus ripped it without a hitch! Again, limited results suggest the drive itself does make a difference.
YMMV...
~S
#22 Post by MartyMcNuts » Sun Jul 20, 2025 1:50 am
seamus wrote: Sat Jul 19, 2025 10:52 pm
  • Zero BD failures
YMMV...
~S
I don't see what the problem is.... If i wanted to rip a DVD and MakeMKV was having trouble doing it, I would not heistate to go back to using those older, tried and tested DVD ripping applications. So what if they are old. Nothing has really changed with DVD over the years so there's no need for newer versions.
And yes, drive's do make a difference. A silly as it sounds, some drives just don't like some discs. This goes for all disc types. This is one of the reasons why most of us have multiple (different model/manufacturer)drives.
seamus
#23 Post by seamus » Sun Jul 20, 2025 7:54 pm
MartyMcNuts wrote: Sun Jul 20, 2025 1:50 am
I don't think I said there was a problem, per se. I was just commenting on dcoke22's post where he said:
Since it is a DVD, just about any drive will work ...
