[Solved] ASUS BW-16D1HT - Unable to Read UHD
Perillex
Post by Perillex »
I bought the GoT complete 4k collection, unfortunately it is the only 4k video discs I own.
I was able to get Season 4 disc 1 to read the first time, the second time it just detected it as a writable BD.
The third time would not read at all.
Is this common for older ASUS BW-16D1HT drives?
Is there anything I can do? I am assuming there is not, and I will just need to buy a better drive.
Any help is greatly appreciated!
I have the drive in a VANTEC external case on Windows 11.
I was able to successfully flash it with the recommended firmware.
It is an older ASUS drive from December 2015.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: XXXXXXXXXXXX
Bus encryption flags: 1F
Highest AACS version: 68
Firmware version: 3.10
Re: ASUS BW-16D1HT - Unable to Read UHD
Perillex wrote:
Fri Jul 18, 2025 6:51 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
The GoT discs are really bad. Pioneer drives would work better. Try WH16NS60 1.02 firmware. It works better for 3-layer discs like these.
Perillex
Post by Perillex »
Coopervid wrote:
Fri Jul 18, 2025 7:51 pm
Nope, no dice.
Perillex wrote:
Fri Jul 18, 2025 8:22 pm
Nope, no dice.
Get a Pioneer drive while some are out there. Supply is running dry. Your country of residence?
Perillex
Post by Perillex »
Coopervid wrote:
Fri Jul 18, 2025 8:49 pm
Nope, no dice.
I am in the USA.
I was looking a little bit but cannot find any Pioneer drives. I will continue to look.
I haven't checked ebay yet.
I think I messed up my ASUS drive though. I flashed it with the DE_ASUS_BC-12D2HT_3.11_MK firmware after trying the WH16NS60 1.02 firmware and now it cannot be flashed with any other firmware.
Perillex wrote:
Fri Jul 18, 2025 8:57 pm
Nope, no dice.
I am in the USA.
Look for a Vinpower 212V on Amazon or Newegg.
Nope, no dice.
I am in the USA.
Try using SDFTool Flasher's recovery method to get back to BW-16D1HT 3.10-MK.
Perillex
Post by Perillex »
MartyMcNuts wrote:
Sat Jul 19, 2025 12:41 am
I am in the USA.
I did try using the recovery feature of the SDFTool with multiple firmwares, and it remained the wrong firmware.
I finally found your post based on someone with the same issue. NEW OPTION: 'UHD Friendly' Firmware Downgrade / Cross-Flash Using Official (Modified) ASUS Flasher for ASUS & LG Drives article and was able to downgrade to DE_ASUS_BC-12D2HT_3.00.
After downgrading to DE_ASUS_BC-12D2HT_3.00 using the ASUS_ODD_FW_Changer_(Modified), I was able to upgrade to the DE_ASUS_BW-16D1HT_3.10_MK firmware.
Thank you very much for your work here MartyMcNuts! Also, thank you for your help Coopervid!
I am ripping the second 4k Blu-Ray now. It is still hit or miss though.
I am okay with that until I can afford a better solution.
