Hi Guys, Having some trouble ripping films, I have the samsung SH-B123L Blu-ray drive here:
http://www.amazon.co.uk/gp/product/B003 ... D6C6J73R08
Its running the SB04 firmware
Make MKV seems to get stuck at /AACS/MKB_RO.inf and producing errors about SCSI or something, Ive attatched the log for this
Can anyone help me?
Rob
Cant Rip Any Blu-Rays
Bezzaboy123
- MakeMKV_log.txt
- (17.37 KiB) Downloaded 738 times
- Contact:
Re: Cant Rip Any Blu-Rays
Were you ever able to copy any blu-ray disc with this drive, with MakerMKV or any other program? If you insert a BD disc in this drive and launch MakeMKV, then what is shown in the "protection" field?
Bezzaboy123
Yes I was able to before, Tried lots of programs but they didn't do what I wanted so I tried MakeMKV which was working fine up until now
Okay, I've inserted Transformers: Revenge of the fallen, and in the Protection Field it says: AACS v16
thanks
thanks
I have the same drive with the same firmware. no issues so far beyond damaged discs.
i get the same error which i never got before. last time i ripped blu rays was awhile ago when i ripped Saw VII (saw 3d ythe newest one) then yesterday i tried ripping underworld rise of yththe lycans and it gave mt that error then every disc i try gives error evne ones i know worked b4
underworld says has aacs v7 and original underworld v3,
i read aan admin post formnov 5 saying he had a workaround or something.
what can i do? oh i used version 1.7.0
Have you updated to 1.7.1 ?
Bezzaboy123
Yeah I Did, And Still Nothing!
So I tried running it again with DVD Passkey 8 Installed and Voila!
It Works,
Think there may be something wrong with the MakeMKV disc access/protection possibly?
Anyway if you are having an issue try using third party software like DVD passkey e.t.c
It Works,
- Contact:
Do you have a purchased registration key or are you using current beta key?
Bezzaboy123
Yes I Am Using The Beta MakeMKV,
Not Sure What You Mean Flogger123, But Nothing Has Changed Other Than Me Using DVDPassKey 8 To Open The Disc Before Using MakeMKV to Copy Everything
