Disc Error - Dogma BluRay
NickDaGreek
Post by NickDaGreek »
I am having a failure - only on the movie item. Was able to save all other parts. Tried a system restart, disc cleaning. Only the film will not save.
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
File 00107.mpls was added as title #0
File 00001.mpls was added as title #1
File 00120.mpls was added as title #2
File 00102.mpls was added as title #3
File 00227.mpls was added as title #4
File 00229.mpls was added as title #5
File 00228.mpls was added as title #6
File 00226.mpls was added as title #7
File 00000.m2ts was added as title #8
File 00001.m2ts was added as title #9
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
File 00100.m2ts was added as title #10
File 00101.m2ts was added as title #11
File 00102.m2ts was added as title #12
File 00103.m2ts was added as title #13
File 00104.m2ts was added as title #14
File 00105.m2ts was added as title #15
File 00106.m2ts was added as title #16
File 00107.m2ts was added as title #17
File 00108.m2ts was added as title #18
File 00109.m2ts was added as title #19
File 00110.m2ts was added as title #20
File 00111.m2ts was added as title #21
File 00112.m2ts was added as title #22
File 00113.m2ts was added as title #23
File 00114.m2ts was added as title #24
File 00115.m2ts was added as title #25
File 00116.m2ts was added as title #26
File 00117.m2ts was added as title #27
File 00118.m2ts was added as title #28
File 00119.m2ts was added as title #29
File 00120.m2ts was added as title #30
File 00121.m2ts was added as title #31
File 00122.m2ts was added as title #32
File 00123.m2ts was added as title #33
Title #00124.m2ts has length of 1 seconds which is less than minimum title length of 5 seconds and was therefore skipped
Saving 1 titles into directory F:/Blu_Ray_Cap/Dogma (1999)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '5904070656'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5904070656'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '5904267264'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5904267264'
Failed to save title 1 to file F:/Blu_Ray_Cap/Dogma (1999)/Dogma - 1080p_t01.mkv
Encountered 19 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Disc Error - Dogma BluRay
The optical drive is unable to read a spot on the disc. The standard advice is to gently clean the disc and try again.
