Road Trip UHD problem
obitwan7
Post by obitwan7 » Fri Jul 18, 2025 4:16 am
Sorry if this may be in the wrong spot, but I just went through 2 UHD versions of the movie Road Trip from Kino Lorber. Both discs don't play at all and i checked other UHD discs and they spin-up just fine, but it seems strange that 2 of them in a row have done this. I have 2 Pioneer BDR-212 optical drives from a seller here on these forums, so I know both drives are brand new & working properly.
Anyone else have any troubleshooting tips or ideas? I can try purchasing another from Amazon, but I've never had 2 happen the same way in a row before. I have tried cleaning them & it's crystal clear on the disc, no scratches or anything. Makes me wonder if there's a defect batch or something or if this movie is just plain incompatible with my drives, but I don't have another to test on. It plays fine on my blu-ray player. Hope to hear from someone.
Re: Road Trip UHD problem
Post by MartyMcNuts » Fri Jul 18, 2025 6:55 am
obitwan7 wrote: Fri Jul 18, 2025 4:16 am Sorry if this may be in the wrong spot, but I just went through 2 UHD versions of the movie Road Trip from Kino Lorber. Both discs don't play at all and i checked other UHD discs and they spin-up just fine, but it seems strange that 2 of them in a row have done this. I have 2 Pioneer BDR-212 optical drives from a seller here on these forums, so I know both drives are brand new & working properly.
So what happens? What does the log window say?
polskasubie
Post by polskasubie » Fri Jul 18, 2025 11:53 am
i had to get a replacement copy for my Road Trip UHD as well... def must be a defective batch out there... i got my copy from Target but replacement copy ripped without issues...
obitwan7
Post by obitwan7 » Sat Jul 19, 2025 5:22 am
The 2nd replacement was from Amazon and I managed to use a friend's optical drive and that worked. Doesn't do me good if I need to rip it again from my 2 drives, so I think those 2 discs were my Pioneer drives being incompatible somehow, but you would think that each drive failed for 2 of the UHD version and I didn't want to buy another one, unless I had to. Now that it's ripped I may keep an extra copy separately (just in case).
Just as an additional separate question. When new movies are released and we get that .tqz error. Why doesn't MakeMKV just rip the discs? I know it needs something to work and it starts working after around a week or so after release, but when i got those...I tried using DVDFab and that didn't need anything to work. I don't like DVDFab, but was curious about it. I submit those .tqz as well, but don't understand it.
Post by dcoke22 » Sat Jul 19, 2025 12:09 pm
obitwan7 wrote: Sat Jul 19, 2025 5:22 am The 2nd replacement was from Amazon and I managed to use a friend's optical drive and that worked. Doesn't do me good if I need to rip it again from my 2 drives, so I think those 2 discs were my Pioneer drives being incompatible somehow, but you would think that each drive failed for 2 of the UHD version and I didn't want to buy another one, unless I had to. Now that it's ripped I may keep an extra copy separately (just in case).
MakeMKV uses something called Hashed Keys to unlock UHDs. MakeMKV downloads these hashed keys in the background. When MakeMKV encounters a disc for which no hashed key exists, it produces the dump file, which users email to svq@makemkv.com so a hashed key can be created.
MakeMKV allows for making a full disc backup. On the first screen, click the icon of the yellow folder with the green arrow. Even if MakeMKV can not yet decrypt a disc, an encrypted backup can be made (it'll copy the entire contents of the disc to a folder on your local storage). After a hashed key is available, the backup can be opened, decrypted, and .mkv files created from it just as if you were doing it from the disc.
UHD FAQ
Separately from the hashed key mechanism MakeMKV uses, it also supports an additional disc unlocking process called KeyDB. This requires you to download a public list of keys and put it in the right spot so MakeMKV can find it. The keydb is often updated faster than the hashed keys MakeMKV uses, but requires a bit of manual labor on your part to use. There's no harm in using both mechanisms. If you get a new disc and there's no key, email the dump file svq@makemkv.com and submit it to the KeyDB.
TheThomasTrinity
Post by TheThomasTrinity » Tue Dec 09, 2025 12:14 am
I got the movie in the mail from Amazon and when it arrived I tried to rip it, but the disk would just eject after a moment of the drive spinning up. I thought, the disk might be defective and got a replacement sent out. I got the replacement today and I'm having the same issue. I decided to try the included blu-ray and that's doing just fine. I have a Pioneer BDR-XS07UHD drive.
davahad
Post by davahad » Wed Mar 25, 2026 1:50 am
Ripped over a 100 different UHD discs with no issues on Pioneer BDR-212. Recd Road Trip UHD from Amazon and when try opening in MakeMKV shows no disc.
Got a replacement Road Trip UHD from Amazon and also shows no disc. Tried another Pioneer BDR-212 drive and same issue shows No disc.
Downloaded the keydb.cfg and placed in the MakeMKV data directory and still shows no disc.
So it is either a bad disc (which seems unlikely) or not compatible somehow with Pioneer 212?
Any ideas?
Post by MartyMcNuts » Wed Mar 25, 2026 5:34 am
davahad wrote: Wed Mar 25, 2026 1:50 am Ripped over a 100 different UHD discs with no issues on Pioneer BDR-212. Recd Road Trip UHD from Amazon and when try opening in MakeMKV shows no disc.
Any ideas?
Did you clean the disc? 99.9% of UHD discs require cleaning, even if they look pristine, as they often have an invisible to the naked eye layer of film on them from the manufacturing process.
davahad
Post by davahad » Wed Mar 25, 2026 9:18 pm
Yes discs are clean. Tried a 3rd drive on a different computer and disc had numerous read errors. Seems like there are issues with this title and BDR212.
