The Substance
Space
The Substance
Post by Space »
It’s showing as failed to open disc and dumped a tgz file. I have the newest KEYDB.cfg dropped in the .Makemkv folder. It’s the first time I’ve had to download the cfg file. I assume I have it in the wrong spot? This disc must have been submitted months ago, it’s not that new.
keydb_helper
Re: The Substance
Post by keydb_helper »
Space wrote: Thu Jul 17, 2025 12:31 am This disc must have been submitted months ago, it’s not that new.
Upload the disc dump file to a file host and post the link here. Just because a disc is several months or even years old doesn't mean it has been added.
Public KeyDB Disc Submissions
Space
Re: The Substance
Post by Space »
keydb_helper wrote: Thu Jul 17, 2025 6:37 am
Dump submitted for The Substance
https://drive.google.com/file/d/1rQ5qmY ... p=drivesdk
keydb_helper
Re: The Substance
Space wrote: Fri Jul 18, 2025 1:26 am Dump submitted for The Substance
Can you please enable public access for that file?
Space
Re: The Substance
Post by Space »
keydb_helper wrote: Fri Jul 18, 2025 1:51 am
Fixed, sorry first time using Google drive.
keydb_helper
Re: The Substance
Space wrote: Fri Jul 18, 2025 2:26 am Fixed, sorry first time using Google drive.
No worries, thanks for fixing the link.
Your particular disc variant was added to the public keydb on June 13th. Try to follow my instructions here.
If you can download the keydb zip file and extract it to the same folder where you found that MKB20_v77_THE_SUBSTANCE_357F.tgz file you will be able to decrypt your disc with MakeMKV.
