The Substance
The Substance
It’s showing as failed to open disc and dumped a tgz file. I have the newest KEYDB.cfg dropped in the .Makemkv folder. It’s the first time I’ve had to download the cfg file. I assume I have it in the wrong spot? This disc must have been submitted months ago, it’s not that new.
keydb_helper
Re: The Substance
Upload the disc dump file to a file host and post the link here. Just because a disc is several months or even years old doesn't mean it has been added.
Public KeyDB Disc Submissions
Re: The Substance
Dump submitted for The Substancekeydb_helper wrote: ↑Thu Jul 17, 2025 6:37 amUpload the disc dump file to a file host and post the link here. Just because a disc is several months or even years old doesn't mean it has been added.
https://drive.google.com/file/d/1rQ5qmY ... p=drivesdk
keydb_helper
Re: The Substance
Can you please enable public access for that file?
Re: The Substance
Fixed, sorry first time using Google drive.
keydb_helper
Re: The Substance
No worries, thanks for fixing the link.
Your particular disc variant was added to the public keydb on June 13th. Try to follow my instructions here.
If you can download the keydb zip file and extract it to the same folder where you found that MKB20_v77_THE_SUBSTANCE_357F.tgz file you will be able to decrypt your disc with MakeMKV.
