seamus
#31
Post
by seamus » Thu Jul 17, 2025 3:35 pm
dcoke22 wrote: Sun Jun 29, 2025 1:09 pm
I have the movie
Zack Snyder's Justice League (2021) which is too big to fit on a single disc, consequently, I have two .mkv files that make up the entire movie.
I do most of my movie watching via Plex. Plex has a feature that allows for a movie to be split across multiple files. (
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/) Fortunately for this movie, the split happens during a transition with a black screen so it is almost unnoticeable when playing via Plex.
Playback systems other than Plex might have similar functionality. If the publishers of the discs have put the transition between discs in a convenient spot, using that functionality might mean one does not need to combine two .mkv files into one.
I do all of my movie-watching via JellyFin. AFAICS, Jellyfin has no functionality that allows you to "merge" two separate mkv files together during watching... if someone knows differently I would really appreciate some feedback! I also looked into merging with FFmpeg, but that seems to be quite complicated due to all of the "tracks" (audio, subtitles, video, etc). And the other solution mentioned here (this thread) requires a Windows box, which I do not have.
So yeah - for at least some of us - a "merge" feature in MakeMKV would be quite useful.
#32
Post
by dcoke22 » Thu Jul 17, 2025 3:47 pm
seamus wrote: Thu Jul 17, 2025 3:35 pm
I have the movie
https://jellyfin.org/docs/general/server/media/movies/#multiple-parts
It would seem that Jellyfin does support movies that have multiple parts. Since I don't use Jellyfin, I have not tried it.
#33
Post
by d00zah » Thu Jul 17, 2025 3:49 pm
JellyFin, being an early fork of MediaBrowser 3/Emby, supports multi-part playback (when properly named).
https://features.jellyfin.org/posts/198 ... s-one-item
https://jellyfin.org/docs/general/serve ... ovies.html
https://emby.media/support/articles/Movie-Naming.html (see 'Split video files (file stacking)' section)
& MKVToolNix (free, multi-platform tool) can easily merge multipart releases (if that is your goal).
https://www.youtube.com/watch?v=xTGWYkB9M4A
seamus
#34
Post
by seamus » Fri Jul 18, 2025 5:21 am
I've not had a chance to try this, but it looks promising - Thank You!
My bad! I'm sure I read somewhere that MKVToolNix was only for Windows, but you are correct -
downloads for MKVToolNix are available here for most versions of macOS. The Jellyfin links will be handy also - a
Double Thank You
charlesaa
#35
Post
by charlesaa » Mon Jul 21, 2025 7:06 am
MKVToolNix (recommended) – Merge multiple MKV files seamlessly while preserving chapters and sync.
Plex/Jellyfin (auto-play) – Play split DVD files sequentially without merging, using media server detection.
FFmpeg (direct VOB merge) – Combine DVD VOB files losslessly via ffmpeg -i "concat:VTS_01_1.VOB|VTS_01_2.VOB" -c copy output.mkv.
Cisdem Video Converter (paid but easy-to-use program) – Rip DVD to any video format and one-click to merge within the software.
