Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
At least we have clarified one point. You were talking about your UD03 but since it's flashed already to UD04 you should have called it UD04. And that was the Makemkv info you posted above.
I would also like some help with my drive, if possible. The drive information is as follows:
Thanks in advance.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: OBDL035864WL
Firmware date: 2014-05-14
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.00/ID84
Unrestricted read speed: YesRe: Pioneer BDR-UD03 UHD possibility
PM sent.dtech wrote: Wed Jul 16, 2025 2:58 pm I would also like some help with my drive, if possible. The drive information is as follows:
Thanks in advance.Code: Select all
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03D Revision: 1.00 Serial number: OBDL035864WL Firmware date: 2014-05-14 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.00/ID84 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Verbatim 43890 branded Pioneer BDR-UD03
Hello Coopervid & Co.!
I own an external Verbatim branded USB 3.0 slimline Blu-ray writer (Verbatim#43890) from Pioneer and want to enhance it (and alo prevent it from "forced software degration"):
MakeMKV v1.18.1 win(x64-release) gestartet
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: ------------
Firmware-Datum: 2018-11-28
Highest AACS version: 62
Drive platform: RS8511
Firmware version: 1.11
Keine Disk eingelegt
I'll appreciate it if you could send me that special PM :-).
Greetings
eRGo1896
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
Re: Verbatim 43890 branded Pioneer BDR-UD03
PM sent.eRGo1986 wrote: Wed Jul 16, 2025 7:27 pm Hello Coopervid & Co.!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
I'll appreciate it if you could send me that special PM.
Greetings
eRGo1896
any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: 1.10
Revision: 1.10
Serial number: ...
Sure email me that drive info see belowJ8GDN wrote: Thu Jul 17, 2025 9:16 am any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
cheers, will sort on Monday
Hi Coopervid,Coopervid wrote: Wed Jul 16, 2025 8:28 pmPM sent.eRGo1986 wrote: Wed Jul 16, 2025 7:27 pm Hello Coopervid & Co.!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
I also have a PIONEER BD-RW BDR-UD03 with fw 1,14 and need help to make it UHD ready. Can you help me?
Please post your own Makemkv info.joshi21 wrote: Sun Aug 03, 2025 12:45 amHi Coopervid,Coopervid wrote: Wed Jul 16, 2025 8:28 pmPM sent.eRGo1986 wrote: Wed Jul 16, 2025 7:27 pm Hello Coopervid & Co.!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
Coopervid wrote: Sun Aug 03, 2025 9:34 amPlease post your own Makemkv info.joshi21 wrote: Sun Aug 03, 2025 12:45 amHi Coopervid,Coopervid wrote: Wed Jul 16, 2025 8:28 pm
Here it is:
OS-Gerätename: /dev/rdisk6
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.14
Serienummer: CIDL505512WL
Firmware-Datum: 2020-06-15
Highest AACS version: 20
Firmware version: 1.14
PM sent.
PM sent. Wanted to make sure it's not a combo that can't be flashed.
Coopervid wrote: Mon Aug 04, 2025 8:21 pmPM sent. Wanted to make sure it's not a combo that can't be flashed.
Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
No I use a M1 Max MacBook Pro running Windows 11 with Parallels.Coopervid wrote: Wed Aug 06, 2025 4:41 am Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
