Pioneer BDR-XS07TUHD newbie help
oldie
Post by oldie » Thu Jul 17, 2025 6:21 am
I have an external/USB Pioneer BDR-XS107UHD drive. It works a treat with MakeMKV for standard BR discs but when I try a UHD disc it tells me it is not supported. [Incidentally as do other player applications to just play the disc]
I have had a snoop through this forum but it wasn't clear to me if this drive is able to be firmware patched to support UHD discs and if it is how I go about it. I saw the flasher tool and the all you need firmware but there didn't seem to be anything relevant to this drive there.
MakeMKV reports the drive info as...
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: <xxx>
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 68
Firmware version: ID05
Any pointers on how to get started/where to look much appreciated!
Thanks in advance.
Re: Pioneer BDR-XS07TUHD newbie help
Post by Billycar11 » Thu Jul 17, 2025 7:04 am
sorry cant be flashed fw needs to be before 12/22
Post by MartyMcNuts » Thu Jul 17, 2025 7:08 am
oldie wrote: Thu Jul 17, 2025 6:21 am I have an external/USB Pioneer BDR-XS107UHD drive. It works a treat with MakeMKV for standard BR discs but when I try a UHD disc it tells me it is not supported. [Incidentally as do other player applications to just play the disc]
OS device name: G:
Revision: 1.03
Thanks in advance.
Nothing can be done with your drive yet. The firmware on it is too new. You will just have to wait for support. It is coming, sometime in the future.
oldie
Post by oldie » Thu Jul 17, 2025 7:09 am
Thanks for the response…much appreciated.
