Error 'OS error - {Device Timeout}
el_dustino
#1 Post by el_dustino » Wed Jul 16, 2025 5:00 am
New to using MakeMKV, but I have a new drive, details below. I insert a DVD, couple a clips and voila everything works. But when I try a Blu-Ray (using Harry Potter 8-disc) I get some version of the same error. I have cleaned
Appears to start ripping fine, then slows to 0.8x, time remaining starts going up, then errors begin appearing. Just one example is below, but they just keep going until it fails. I have cleaned the drive and increased the read retry count. I have also plugged the USB into different ports on the computer (saw that on some posts). I can't find where the faq/item/7 is to look for more options so I thought I'd post. I can't even tell what is erroring with the read out, what's "{Device Timeout} " what is "hs"? Anyway, I'll keep ripping old DVDs but would like to get the Blu-Ray working as well. Thanks in advance for any help.
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11766263808'
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.01
Serial number: CIDL053312WL
Firmware date: 2020-07-21
Drive platform: RS8F01
Firmware version: 1.01/ID83
Connected via USB with external power. I don't have another drive to try.
Re: Error 'OS error - {Device Timeout}
#2 Post by dcoke22 » Wed Jul 16, 2025 3:47 pm
Do you get the same error with several different blu-ray discs?
el_dustino
#3 Post by el_dustino » Wed Jul 16, 2025 11:29 pm
Yes. I have tried 3 discs so far but the errors start occuring about 10 minutes in, they all say something similar. I also selected the "minimum" playlist with just the main chapter and English language in case that was related somehow. But again, I am not even sure what the error means? What is failing?
#4 Post by dcoke22 » Thu Jul 17, 2025 12:31 am
How is the drive powered? Only via USB?
What that error implies is the computer asked the optical drive to read a spot on the disc and then it waited for the drive to return the data. It never did and eventually the computer timed out waiting for it.
el_dustino
#5 Post by el_dustino » Thu Jul 17, 2025 2:11 am
It is connected via USB but powered by an external power source. I have this enclosure: https://a.co/d/3KSbeIR
I wonder if my computer is going to sleep or powering down somehow? I have the power settings so the screen turns off at 10 minutes, then the device sleeps at 1 hour and never hibernates but maybe the screen turning off is affecting it? I'll play around with that and make sure nothing turns off during a rip.
#6 Post by dcoke22 » Thu Jul 17, 2025 2:46 pm
I have two of those OWC enclosures. They're pretty good pieces of kit.
el_dustino
#7 Post by el_dustino » Fri Jul 18, 2025 2:32 am
Yes the enclosure seems to work fine, even if the mounting screws don't align with my Pioneer 212 drive :cry: So I switched to a completely different Blu-ray box set (Hobbit 3D BD) and that ripped just fine, no errors, even though it took longer. So it isn't a Blu-ray global issue. I also found one of the Harry Potter BD that would rip (disc 3) But disc 1, 2 and others get this error. Is there something complicated/different about the Harry Potter Complete 8-Film Collection Blu-Ray set that could be causing this issue? Any setting? Here is the information it shows for disc 1 that gets this error:
Disc Information
Label: HARRY_POTTER
Timestamp: 2007-10-02 11:52:41
Protection: AACS v4
Data capacity: 29.77 Gb
Disc type: BD-ROM
Number of layers: 2
el_dustino
#8 Post by el_dustino » Fri Jul 18, 2025 5:02 am
Well 6 of the 8 discs work. 2 of them just must be bad. What threw me was the errors I was getting, which seemed a bit different from others I was seeing on the forum. So I'll just try to find a different disc and give it another go.
