Are Pioneer drives *that* much better at ripping scuffed blurays?
I currently have an Asus BW-16D1HT drive that is Libredrive compatible; however, it has issues ripping even non-UHD bluray discs that are used or not in pristine condition. It can rip the one UHD disc I have, but that is in brand new condition.
So, is it worth it to get a Pioneer drive? It seems like they have shot up in price over the past couple of days, with the BDR-212V at around 150 dollars. I'm concerned with its ability to rip non-UHD blurays that are in used condition.
Does anyone have both the BW-16D1HT and a Pioneer drive? Has the Pioneer been able to rip a disc that the Asus drive can't? Thanks for any info.
Re: Are Pioneer drives *that* much better at ripping scuffed blurays?
You've got to hurry. Yes. They are better readers and writers. And ASUS / LG's tend to die early.
So what Pioneer drive would you recommend of the ones that are still available? I'm not concerned about UHD compatibility right now since apparently all Pioneer drives should work in the future. An external model (like the BDR-XS07S) is tempting for the portability but I don't know how they are for longevity. There's also one that's top loading which might last longer. I can use a 5.25 internal drive as well but not sure what would be best for that size either.
Most are now hard to get. Depends on your region. Production has stopped. Seller Asmcom is on vacation and he has the largest stock that will be soon gone. So tell me your country of residence.xenphor wrote: ↑Wed Jul 16, 2025 8:09 pmSo what Pioneer drive would you recommend of the ones that are still available? I'm not concerned about UHD compatibility right now since apparently all Pioneer drives should work in the future. An external model (like the BDR-XS07S) is tempting for the portability but I don't know how they are for longevity. There's also one that's top loading which might last longer. I can use a 5.25 internal drive as well but not sure what would be best for that size either.
You can maybe still find a Vinpower 212V on Newegg or Amazon. It needs to be flashed. Post when you have it.
Is that still the best option even if I'm not concerned with UHD compatibility right now? Supposedly all Pioneer drives will be compatible in the future.
Do the Vinpower drives have any special branding or labels? I see there is one on Amazon that is listed under the Vinpower store but is sold by a 3rd party and looks like a normal Pioneer drive.
zaqqaz6917
This with amazon prime ie free shipping and free returns. Can also be purchased by non prime
https://www.amazon.com/Pioneer-BDR-212V ... 255&sr=8-1
I did end up getting one of those (waiting for it to arrive) as well as a BDR-XS07S model off ebay as a backup if new firmware is ever made available for it.zaqqaz6917 wrote: ↑Thu Jul 17, 2025 9:17 pmThis with amazon prime ie free shipping and free returns. Can also be purchased by non prime
Just post your Makemkv info for both drives when you get them. If you are lucky the XS07 has old firmware.xenphor wrote: ↑Thu Jul 17, 2025 11:35 pmI did end up getting one of those (waiting for it to arrive) as well as a BDR-XS07S model off ebay as a backup if new firmware is ever made available for it.zaqqaz6917 wrote: ↑Thu Jul 17, 2025 9:17 pmThis with amazon prime ie free shipping and free returns. Can also be purchased by non prime
I received the Vinpower drive. Here is the info:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ....
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06Re: Are Pioneer drives *that* much better at ripping scuffed blurays?
PM sent.xenphor wrote: ↑Sun Jul 20, 2025 4:02 amI received the Vinpower drive. Here is the info:
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: .... Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
