Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
At least we have clarified one point. You were talking about your UD03 but since it's flashed already to UD04 you should have called it UD04. And that was the Makemkv info you posted above.
dtech
Post by dtech »
I would also like some help with my drive, if possible. The drive information is as follows:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: OBDL035864WL
Firmware date: 2014-05-14
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.00/ID84
Thanks in advance.
dtech wrote: Wed Jul 16, 2025 2:58 pm I would also like some help with my drive, if possible. The drive information is as follows:
OS device name: F:
Revision: 1.00
Thanks in advance.
PM sent.
eRGo1986
Verbatim 43890 branded Pioneer BDR-UD03
Post by eRGo1986 »
Hello Coopervid & Co.!
I own an external Verbatim branded USB 3.0 slimline Blu-ray writer (Verbatim#43890) from Pioneer and want to enhance it (and alo prevent it from "forced software degration"):
MakeMKV v1.18.1 win(x64-release) gestartet
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: ------------
Firmware-Datum: 2018-11-28
Highest AACS version: 62
Drive platform: RS8511
Firmware version: 1.11
Keine Disk eingelegt
I'll appreciate it if you could send me that special PM :-).
Greetings
eRGo1896
Re: Verbatim 43890 branded Pioneer BDR-UD03
eRGo1986 wrote: Wed Jul 16, 2025 7:27 pm Hello Coopervid & Co.!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
J8GDN
Post by J8GDN »
any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: 1.10
J8GDN wrote: Thu Jul 17, 2025 9:16 am any help appreciated - looks to have old firmware and can this be flashed to enable UHD - novice so bear with me. thanks J
Revision: 1.10
Serial number: ...
Sure email me that drive info see below
J8GDN
Post by J8GDN »
cheers, will sort on Monday
joshi21
Post by joshi21 »
Coopervid wrote: Wed Jul 16, 2025 8:28 pm
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
Hi Coopervid,
I also have a PIONEER BD-RW BDR-UD03 with fw 1,14 and need help to make it UHD ready. Can you help me?
joshi21 wrote: Sun Aug 03, 2025 12:45 am
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Greetings
eRGo1896
PM sent.
Hi Coopervid,
Please post your own Makemkv info.
joshi21
Post by joshi21 »
Coopervid wrote: Sun Aug 03, 2025 9:34 am
Here it is:
OS-Gerätename: /dev/rdisk6
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.14
Serienummer: CIDL505512WL
Firmware-Datum: 2020-06-15
Highest AACS version: 20
Firmware version: 1.14
BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.
Hi Coopervid,
joshi21 wrote: Mon Aug 04, 2025 8:12 pm
Hi Coopervid,
PM sent. Wanted to make sure it's not a combo that can't be flashed.
joshi21
Post by joshi21 »
Coopervid wrote: Mon Aug 04, 2025 8:21 pm
Hi, thank you for your PM. I tried it an unfortunately the Software shows "Selected drive is not a Pioneer drive". Although the dropdown lists it as a Pioneer.
Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
joshi21
Post by joshi21 »
Coopervid wrote: Wed Aug 06, 2025 4:41 am Use a Windows PC or VMware. You seem to be on Linux and that is the issue.
No I use a M1 Max MacBook Pro running Windows 11 with Parallels.
