Are Pioneer drives *that* much better at ripping scuffed blurays?
xenphor
Post by xenphor »
I currently have an Asus BW-16D1HT drive that is Libredrive compatible; however, it has issues ripping even non-UHD bluray discs that are used or not in pristine condition. It can rip the one UHD disc I have, but that is in brand new condition.
So, is it worth it to get a Pioneer drive? It seems like they have shot up in price over the past couple of days, with the BDR-212V at around 150 dollars. I'm concerned with its ability to rip non-UHD blurays that are in used condition.
Does anyone have both the BW-16D1HT and a Pioneer drive? Has the Pioneer been able to rip a disc that the Asus drive can't? Thanks for any info.
Re: Are Pioneer drives *that* much better at ripping scuffed blurays?
You've got to hurry. Yes. They are better readers and writers. And ASUS / LG's tend to die early.
xenphor
Post by xenphor »
Coopervid wrote: Wed Jul 16, 2025 5:37 pm You've got to hurry. Yes. They are better readers and writers. And ASUS / LG's tend to die early.
So what Pioneer drive would you recommend of the ones that are still available? I'm not concerned about UHD compatibility right now since apparently all Pioneer drives should work in the future. An external model (like the BDR-XS07S) is tempting for the portability but I don't know how they are for longevity. There's also one that's top loading which might last longer. I can use a 5.25 internal drive as well but not sure what would be best for that size either.
xenphor wrote: Wed Jul 16, 2025 8:09 pm
Most are now hard to get. Depends on your region. Production has stopped. Seller Asmcom is on vacation and he has the largest stock that will be soon gone. So tell me your country of residence.
xenphor
Post by xenphor »
Coopervid wrote: Wed Jul 16, 2025 8:14 pm Most are now hard to get. Depends on your region. Production has stopped. Seller Asmcom is on vacation and he has the largest stock that will be soon gone. So tell me your country of residence.
USA
xenphor wrote: Wed Jul 16, 2025 8:35 pm
USA
You can maybe still find a Vinpower 212V on Newegg or Amazon. It needs to be flashed. Post when you have it.
xenphor
Post by xenphor »
Coopervid wrote: Wed Jul 16, 2025 8:38 pm
Is that still the best option even if I'm not concerned with UHD compatibility right now? Supposedly all Pioneer drives will be compatible in the future.
xenphor wrote: Wed Jul 16, 2025 8:44 pm
Yes. Production has stopped. You will not be able to buy a Pioneer drive in the future.
xenphor
Post by xenphor »
Coopervid wrote: Wed Jul 16, 2025 8:48 pm Yes. Production has stopped. You will not be able to buy a Pioneer drive in the future.
Do the Vinpower drives have any special branding or labels? I see there is one on Amazon that is listed under the Vinpower store but is sold by a 3rd party and looks like a normal Pioneer drive.
Get it.
zaqqaz6917
Post by zaqqaz6917 »
xenphor wrote: Wed Jul 16, 2025 9:00 pm
This with amazon prime ie free shipping and free returns. Can also be purchased by non prime
https://www.amazon.com/Pioneer-BDR-212V ... 255&sr=8-1
xenphor
Post by xenphor »
zaqqaz6917 wrote: Thu Jul 17, 2025 9:17 pm This with amazon prime ie free shipping and free returns. Can also be purchased by non prime
I did end up getting one of those (waiting for it to arrive) as well as a BDR-XS07S model off ebay as a backup if new firmware is ever made available for it.
xenphor wrote: Thu Jul 17, 2025 11:35 pm
Just post your Makemkv info for both drives when you get them. If you are lucky the XS07 has old firmware.
xenphor
Post by xenphor »
Coopervid wrote: Fri Jul 18, 2025 10:31 am Just post your Makemkv info for both drives when you get them. If you are lucky the XS07 has old firmware.
I received the Vinpower drive. Here is the info:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ....
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
xenphor wrote: Sun Jul 20, 2025 4:02 am
Revision: 1.02
Serial number: ....
PM sent.
