UHD drive working on Windows but not on Linux (Ubuntu)
sgtCalamari
#1 Post by sgtCalamari » Tue Apr 02, 2024 12:54 am
Drive flashed using SDFtool Flasher and working to rip UHD movies on Windows, but not working for the same movies on Linux. Both are running MakeMKV version 17.5 and tested on the same day. I've tried downgrading to version 17.4 and upgrading to version 17.6 but all Linux versions produce the same result. Other discs including DVD and Blu-Ray can be processed on both operating systems with this drive, with only UHD to fail on Linux. The "Enable Internet access" preference is enabled and I've attempted system restart, but the error persists.
Drive Information: Archgon MD-8107S-U3-UHD
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOFN#######
Highest AACS version: 77
Firmware version: 1.03
MakeMKV v1.17.5 linux(x64-release) started
The new version 1.17.6 is available for download at http://www.makemkv.com/download/
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
... [more of these same messages] ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as home/<user>/.MakeMKV/MKB20_v77_MARVEL_STUDIOS'_GUARDIANS_OF_THE_GALAXY_VOL_3_-_ULTRA_HD_6734.tgz
moneyisreal
Re: UHD drive working on Windows but not on Linux (Ubuntu)
#2 Post by moneyisreal » Wed Oct 02, 2024 3:49 pm
Hey - I had the same issue. I noticed I would get this error right when I opened MakeMVK and before I clicked on the disk "Failed to get full access to drive "[insert drive name]". Make sure that you either have write access to device "/dev/sr0", are member of "cdrom" group or have CAP_SYS_RAWIO enabled.
It seems linux needs to be given access to the drive.
This reddit post helped: https://www.reddit.com/r/makemkv/commen ... ?rdt=57857
They suggest this command: sudo snap connect makemkv:optical-write :optical-drive
#3 Post by Billycar11 » Wed Oct 02, 2024 11:29 pm
Go to bu40n 1.00
lamperino
#4 Post by lamperino » Wed Jul 16, 2025 3:09 am
Billycar11 wrote: Wed Oct 02, 2024 11:29 pm Go to bu40n 1.00
Where can I download the 1.00 firmware? I am having the same issue as the original author but I can't seem to find the 1.00 firmware. All in one firmware pack only has the 1.03MK firmware for the BU40N.
Also sorry for necroing this post but I figured it was better than creating a brand new thread.
#5 Post by dcoke22 » Wed Jul 16, 2025 1:16 pm
lamperino wrote: Wed Jul 16, 2025 3:09 am
On the first post on the SDFtool Flasher thread, near the bottom is a link to a "All You Need Firmware Pack". Even though it is named similarly to the firmware pack Billycar11 provides, this one from MartyMcNuts has a few more firmwares in it, including the BU40N 1.00 version.
lamperino
#6 Post by lamperino » Thu Jul 17, 2025 1:28 am
dcoke22 wrote: Wed Jul 16, 2025 1:16 pm
Thank you very much for pointing that out! I kept looking for it elsewhere and could not find it. Thanks again
