HP and the Sorcerer's Stone won't rip on 3 drives
Ace77
#1 Post by Ace77 » Wed Jul 16, 2025 1:36 am
I have the 8 disc Harry Potter UHD collection, and discs 2-8 rip perfectly fine, but disc 1 (Harry Potter and the Sorcerer's Stone) will not rip. I have three UHD friendly drives, two Pioneer's and one ASUS, and none of the three will rip it. I've tried cleaning the disc and tried multiple times on each drive with no luck.
I tried to attach a screenshot, but I don't think I have permissions to. Here is the error message I am getting. Any ideas if there's anything else I can try? Thank you!
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1816590336'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1816590336'
Re: HP and the Sorcerer's Stone won't rip on 3 drives
#2 Post by MartyMcNuts » Wed Jul 16, 2025 2:17 am
The drive is having trouble reading the disc. If cleaning with soapy water and a microfiber cloth doesn't help, the disc may be bad and require replacing.
You could also try cleaning the drive lasers but if other discs work fine then the issue is most likely the disc.
borouck
#3 Post by borouck » Fri Nov 28, 2025 6:27 pm
I'm having the same issue with the same 8disc box set. Thinking it's a problem with this set :/
