BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Thank you.
By the way, when I checked the Pioneer website, I found that the firmware for the BDR-211M is 1.5x (1.51, 1.52, 1.53...), but the BDR-211M I have is 1.02. Do you know why this is?
Here you see that they started with 1.02 and then switched to 1.5x.
https://www.cdrinfo.pl/hardware/806-Pioneer-BDR-S11J-X
The 211 is the OEM version of S11 w/o software.
thanks for the information
Hate to be a bother, but seeing if you can help out.
billem wrote: ↑Mon Jul 07, 2025 10:06 pmYet another request if you would be so kind.
Drive Information OS device name: /dev/rdisk10 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: [removed] Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
PM sent.billem wrote: ↑Mon Jul 14, 2025 3:17 amHate to be a bother, but seeing if you can help out.
Hello - Please let me know if this Pioneer BDR-212V can be enabled to get UHD. - Thanks for the help!
Revision: 1.02
Revision: 1.02
PM sent.jbmkvhd wrote: ↑Thu Jul 17, 2025 6:18 pmHello - Please let me know if this Pioneer BDR-212V can be enabled to get UHD. - Thanks for the help!
Revision: 1.02
Hi, I purchased a Pioneer BDR-212V and need help to have it enabled for reading UHD. This is the info from makemkv. Thanks.
Revision: 1.02
Serial number: [ removed ]
Highest AACS version: 68
Revision: 1.02
PM sent.yellowstarmonkey wrote: ↑Fri Jul 18, 2025 4:59 amHi, I purchased a Pioneer BDR-212V and need help to have it enabled for reading UHD. This is the info from makemkv. Thanks.
Revision: 1.02
Hi, I purchased a Pioneer BDR-212V can you help me enable it for reading UHD. This is the info from makemkv. I have a Windows machine if that's perferable to linux. Thanks!
OS device name: /dev/sr0
Revision: 1.02
Serial number:
Revision: 1.02
Serial number:
windows only for flashingsweetlyBear wrote: ↑Sat Jul 19, 2025 3:39 amHi, I purchased a Pioneer BDR-212V can you help me enable it for reading UHD. This is the info from makemkv. I have a Windows machine if that's perferable to linux. Thanks!
Revision: 1.02
Serial number:
send me that drive info from windows to the email below for the flasher
Hi everyone,
I'll start by apologizing as I'm sure this has been asked a million times before.
I brought an ASUS BW-16D1H-U recently as I have a stack of old DVD's & blu-rays that I want rip so I can watch them on the Zidoo player I just brought but being a basic noob (I grew up when VHS was a thing) I didn't realize that the drive platform played a big part in the ripping of 4K UHD disks.
Is there a way of flashing this drive to make it compatible so I can rip 4K movies? Drive specs attached below
If anyone can help me out I'd really appreciate it.
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 16
Drive platform: RS8F00
Firmware version: E116/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent. You need a Windows PC or a good VM like VMWare.Semi-Noob wrote: ↑Sat Jul 19, 2025 4:31 amHi everyone,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
I purchased a Pioneer BDR-212V. Any help you could give me to update it would be appreciated.
Here's the info from MakeMKV.
OS device name: E:
Revision: 1.02
Serial number: [Redacted]
OS device name: E:
Revision: 1.02
Revision: 1.02
Serial number: (redacted)
Highest AACS version: 62
I have this drive and would like to enable LibreDrive and UHD backups. Please help
Revision: 1.02
