issues with ripping blu-ray
m4keutap89
Post by m4keutap89 » Sun Jul 06, 2025 8:13 pm
here is my device info. some work and some do not. does it need upgraded?
Manufacturer: hp
Product: DVDWBD TS-LB23P
Revision: HB21
Serial number: xxxxxxx
Bus encryption flags: 1E
Highest AACS version: 63
Drive platform: MT1939
Re: issues with ripping blu-ray
Post by dcoke22 » Sun Jul 06, 2025 8:35 pm
Since the drive platform is MT1939, it is too old to be upgraded with firmware to support LibreDrive. If you try, you'll end up bricking your drive.
m4keutap89
Post by m4keutap89 » Sun Jul 06, 2025 10:31 pm
Thanks, i guess that is why it will only do older blu-rays and not all.
any cheap suggestions as i only have about 30 blu ray to rip for my personal server
Post by dcoke22 » Mon Jul 07, 2025 2:30 pm
If you really only have 30-ish discs that won't rip on your current drive, it is probably worth seeing it any of your friends or family have an optical drive gathering dust in a closet you can borrow.
If you want to buy one, Pioneer drives are considered the best. Unfortunately, Pioneer has gotten out of the business of making optical drives. Any Pioneer drive with firmware from December 2022 or later will not support LibreDrive currently. Eventually all Pioneer drives will be supported.
Outside of Pioneer drives, the LG BU40N was considered one of the better drives available. The Verbatim 43888 optical drive comes with a BU40N inside of it. There are several brands that sell a drive that's just a repackaged LG BU40N. Like all LG drives, it'll have to flashed to support LibreDrive. Ultimate UHD Drives Flashing Guide
After the BU40N, it doesn't really matter. Around 2020, quality control for optical drives took a nose dive. The flashing guide has a list of drives that can work. If you go this route, buy whichever one you can find that's the cheapest and buy it from a place with a decent return policy since the drive might arrive DOA.
m4keutap89
Post by m4keutap89 » Mon Jul 07, 2025 9:53 pm
Any blu-ray drive should work past 2015 date if I am not doing 4k correct?
Post by MartyMcNuts » Tue Jul 08, 2025 12:06 am
Correct.
m4keutap89
Post by m4keutap89 » Sun Jul 13, 2025 7:45 pm
This should work for everything. Correct?
BP50NB40
Post by MartyMcNuts » Mon Jul 14, 2025 3:22 am
BP50NB40
If it is SVC NB50 or NB52 on the label underneath the drive (or on side of box) it can also be flashed to enable libredrive and UHD readability.
m4keutap89
Post by m4keutap89 » Mon Jul 14, 2025 1:20 pm
BP50NB40
I keep getting failed on normal blu ray- it’s right out of the box though. And some regular DVD as well. I know it is nb52 and made March 2025
Post by MartyMcNuts » Tue Jul 15, 2025 7:47 am
BP50NB40
Clean the disc. See if that helps.
m4keutap89
Post by m4keutap89 » Sat Aug 02, 2025 1:39 am
i got it all flashed over, so far it works, some blu rays fail but it more than likely is the disc itself. my key expired today so cant try any more, waiting for a new one to be posted
