ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR
lllusion
Re: ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR
#31 Post by lllusion » Thu Feb 13, 2025 12:49 am
John Lord wrote: Fri Jul 17, 2020 3:49 am Whenever I get this ILLEGAL REQUEST message, I close MakeMKV, then run VLC....
Hope this helps people who have been getting this error.
This solved the issue for me. The only difference is that MakeMKV can remain open while launching VLC and opening the DVD. VLC can remain open if desired. Open Disc has to reinitiated in MakeMKV in order to access the disk and scan contents.
zipsick
#32 Post by zipsick » Tue Feb 18, 2025 11:24 pm
Hello. New here. Got message too. this one:Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL HL-DT-ST DVDRAM GUE1N ME03 KWFJ6HI4903' at offset '1048576'
Tried running as administrator. Then clicked add disc. It reread the dvd ok but only for
2 chapters. i hit the makemkv button but only ripped the 2 chapters. how do I get it to read the whole dvd? please help
lllusion
#33 Post by lllusion » Wed Feb 19, 2025 2:50 am
zipsick wrote: Tue Feb 18, 2025 11:24 pm Hello. New here. Got message too. this one:Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL HL-DT-ST DVDRAM GUE1N ME03 KWFJ6HI4903' at offset '1048576'
Follow the instructions in this post and in my post directly above your post.
Yvee014
#34 Post by Yvee014 » Mon Mar 17, 2025 3:10 pm
KYThrill wrote: Fri Jul 05, 2019 6:14 am I am encountering this same error on v1.14.4. I am also seeing something not yet described. I have two drives, one Libredrive and one not (both LG drives). Not running as admin, I get this error on both drives.
When I run as admin, the Libredrive doesn't give me the Scrambled Sector. The other drive still gives me the error, even as admin. However, that isn't helping me read any addition content (even with errors, Make MKV lists titles).
Further, what appears to be happening when this occurs, is that any content on the 2nd layer of a dual layer disc, is not being read. Disc 1 & Disc 2 of Teen Titans Season 4 both exhibit this behavior. They are dual layer discs. I can successfully copy all the episodes off one layer, but MakeMKV doesn't even see the 2nd layer.
May not be a unique problem to MakeMKV though, because when I play these discs through Cyberlink media player, the menu has all episodes, but it will not play any of the episodes that MakeMKV can't read.
I don't even own a standalone DVD player, but I am going to try and find one to test the discs on to see if those read it. Seems more like it is something were the drives just can't read the 2nd layer of these discs for some reason.
I had the same trouble of ILLEGAL REQUEST...
I tried to flash my BU40N with SDFtool which unfortunately does not open well on my 4K Asus computer's screen (and I was thus unable to use it).
The Hitachi automatic ODD i later on installed also failed to flash my DVD driver.
Finally, I use the "camera" button of MakeMKV. Went to the driver, till the .IFO file.
launched it, got a message of MakeMKV telling me whether I would be happy to open the disk instead of this file. I replied yes...
and then - surprisingly - the ripping started (?????)
Did somebody else observed such a behaviour?
Regards
Yvee014
chuckthetekkie
#35 Post by chuckthetekkie » Sun Jul 13, 2025 2:04 am
I got this error when trying to rip the Wizard of OZ 70th anniversary edition.
The fix was simple. I used the fix mentioned by an above post about running VLC and playing the movie.
As I am using a Mac I opened a Terminal window and went to the directory were the main executable is, in my case:
cd /Applications/MakeMKV.app/Contents/MacOS
I then started playing the movie via VLC.
Then ran the command to give MakeMKV root access:
sudo ./makemkv
At this point no more error and I closed VLC.
DuckLink
#36 Post by DuckLink » Wed Jul 16, 2025 3:08 am
I'm also getting this error. I tried the VLC trick, but VLC doesn't seem to want to read the disc either.
It's not every disc, some work and some don't.
It seems very random as which discs this is effecting.
I've seen it hit older DVDs, and brand new DVDs in a box set while others load just fine.
From the dmesg output it looks like the drive attempts to load, throws the following:
I/O error, dev sr0, sector 16078656 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Buffer I/O error on dev sr0, logical block 2009832, async page read
usb 1-5: reset high-speed USB device number 16 using xhci_hcd
sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_TIME_OUT driverbyte=DRIVER_OK cmd_age=30s
sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 3d 56 88 00 00 38 00
I/O error, dev sr0, sector 16079392 op 0x0:(READ) flags 0x80700 phys_seg 14 prio class 0
INFO: task scsi_eh_6:5074 blocked for more than 122 seconds
task:scsi_eh_6       state:D stack:0     pid:5074  tgid:5074  ppid:2      task_flags:0x208040 flags:0x00004000
And ends with a call trace that blocks the device until it's powered off.
Anyone got an idea?
I'd assume if it was a hardware issue I wouldn't be able to read any disc.
mjtb2026
#37 Post by mjtb2026 » Tue Aug 25, 2026 12:28 am
I found this thread because of the error with Teen Titans season 4 disc 1. It's also present on S4D2, S5D1, and S5D2. For anyone else who runs into this in the future:
My discs run fine in my blu-ray player. Cleaning the discs and running MakeMKV as an admin did not fix it. I didn't get around to trying the VLC hack. What did work was unselecting the "play all episodes" file from the rip. As soon as I removed that, everything ran like it did for the first three seasons.
Also, I used MKVToolNix to chop the episodes at the 00:00:04.5 mark to get rid of the WB intro.
Now I just need to figure out why Loki S1D2 hates me so much
