Flashing the Pioneer BDR-209D
HotPotato72
#1 Post by HotPotato72 » Thu Jul 10, 2025 6:40 pm
Dear coopervid,
I recently acquired a Pioneer BDR-209D (MakeMKV info below) and would like to use it to rip some movies I have on 4K to my PC, as I do not own a 4K-capable player at the moment. I've read around the forum for some time and it seems like the point where I should end up is having the firmware of a Pioneer BDR-S11 flashed on my drive. Would you be able to help me out any further with this? I would have loved to solve this by myself and hate to take up some of your time, but it is much appreciated. Wishing you a good one!
Regards,
Hot Potato
DRIVE INFO
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: [redacted]
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51/ID61
Regards,
Hot Potato
Re: Flashing the Pioneer BDR-209D
#2 Post by Coopervid » Thu Jul 10, 2025 8:05 pm
HotPotato72 wrote: Thu Jul 10, 2025 6:40 pm Dear coopervid,
Regards,
Hot Potato
DRIVE INFO
Revision: 1.51
PM sent.
HotPotato72
#3 Post by HotPotato72 » Thu Jul 10, 2025 8:34 pm
Hey coopervid,
Received your PM and sent a small donation your way for providing the help. In case anything is wrong I'll let you know, but it should go well from here. Thanks and have an amazing day!
Regards,
Hot Potato
HotPotato72
#4 Post by HotPotato72 » Sat Jul 12, 2025 10:21 am
Dear coopervid,
I tried to flash the software several times across the last couple of days, however I am encountering an issue where the software to flash tells me it fails to enter kernel mode. I attached some screenshots below that might aid in figuring out what is going on. Could it possibly be due to my virtual machine configuration? Through a VM is my preferred method, would you know settings I need to look out for? Specifically I use Oracle's Virtualbox on Linux. Your help so far has been much appreciated!
Regards,
Hot Potato
#5 Post by Billycar11 » Sat Jul 12, 2025 1:59 pm
HotPotato72 wrote: Sat Jul 12, 2025 10:21 am Dear coopervid,
Vm bad
#6 Post by Coopervid » Sat Jul 12, 2025 5:48 pm
Use a Windows computer or VMWare.
HotPotato72
#7 Post by HotPotato72 » Mon Jul 14, 2025 2:22 pm
Coopervid wrote: Sat Jul 12, 2025 5:48 pm Use a Windows computer or VMWare.
VMWare did the trick, many thanks for your help! Hope you have a great day :)
Regards,
Hot Potato
