Bad Moms & Bad Moms 2 - Playlist Obfuscation
frameloose
Post by frameloose »
Thought i would leave this in case someone stumble up on it some day
Bad Moms:
This one was the easy one, MakeMKV prioritized the playlist to the top, and i just checked that the segments was in the correct order:
Source file name: 00834.mpls
Duration: 1:40:31
Chapters count: 8
Segment count: 21
Segment map: 514,512,507,505,503,517,515,518,519,506,500,17,513,520,516,511,501,509,502,508,510
File name: Bad Moms-T5_t00.mkv
Bad Moms 2 (A Bad Moms Christmas):
This was a bit harder, neither of PowerDVD, VLC or MPC method gave the correct result. So i ended up just taking a dump of the content and walked it through. Started with the running time, and then just regular expression everything away while removing the bad playlists. This will be the way i do blu-rays in the future for finding the correct playlist. Because for example VLC spent four hours indexing the disc before just playing the segments one by one.
TINFO:151,9,0,"1:44:09"
TINFO:151,10,0,"21.1 GB"
TINFO:151,11,0,"22760214528"
TINFO:151,16,0,"00390.mpls"
TINFO:151,25,0,"21"
TINFO:151,26,0,"519,514,520,516,502,509,517,506,510,504,500,501,503,513,5,511,512,508,507,518,505"
TINFO:151,27,0,"title_t151.mkv"
TINFO:151,30,0,"8 chapter(s) , 21.1 GB"
TINFO:151,31,6120,"<b>Title information</b><br>"
TINFO:151,33,0,"0"TINFO:181,8,0,"8"
