1.7.0 Crashes after "Operation successfully completed"
i12flytoday
Post by i12flytoday » Tue Jan 03, 2012 7:01 pm
Hello...
I'm having a problem with the program crashing after opening a disc. Steps that create the crash every time:
Open MakeMKV
Put disc in drive
Open disc - MakeMKV Goes through and analyzes the disc
MakeMKV Displays "Operation successfully completed"
Then a pop-up window appears that says MakeMKV experienced a fatal error and the program closes.
This happens with every disc, but only the first time for each disc. After it crashes, I open the program again (without restarting my computer) and it reads / converts the disc fine. Upon inserting another disc, it crashes at the same point, just after analyzing the disc. Upon restarting the program, it analyzes the disc and converts it just fine. This happens with every disc every time.
I'm using a Core i7 Quad running Windows 7 Professional 64bit with 8GB Ram
Here is the debug log below:
Debug log started at Tue Jan 03 17:26:13 2012 , written by MakeMKV v1.7.0 win(x64-release)
001005:0000 MakeMKV v1.7.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Wade/MakeMKV_log.txt
003025:0000 Title #2 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #3 was added (1 cell(s), 0:02:12)
Title skip vts=3 pgcn=2 hash=29CE427B0D517948
003025:0000 Title #5 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #7 was added (22 cell(s), 1:57:58)
csf6
Application exited at Tue Jan 03 17:27:07 2012
setarip_old
Re: 1.7.0 Crashes after "Operation successfully completed"
Post by setarip_old » Sun Jan 08, 2012 6:03 pm
Hi!
Open MakeMKV
Put disc in drive
Try reversing the sequence...
Post by mike admin » Tue Jan 10, 2012 7:24 am
i12flytoday wrote: MakeMKV Displays "Operation successfully completed"
Do you get a pop-up window about application crash for makemkvcon.exe ? If not, then if you open a task manager right after the fatal error, do you still see makemkvcon.exe (or makemkvcon64.exe ) running?
i12flytoday
Post by i12flytoday » Thu Jan 12, 2012 9:29 pm
