I get successful rips for video but the file always has no audio. It says audio is DD Dolby Digital - Stereo in the drop down before starting the process. When it successfully finishes it has no audio.
Thanks In advance.
The Worst Of Yucko The Clown no audio
Re: The Worst Of Yucko The Clown no audio
What are you playing it with? You may have a missing audio codec. Try VLC or MPC-HC (included with the K-Lite Mega Codec pack).shockracer wrote: Tue Jul 08, 2025 3:56 am I get successful rips for video but the file always has no audio. It says audio is DD Dolby Digital - Stereo in the drop down before starting the process. When it successfully finishes it has no audio.
Thanks In advance.
shockracer
VLC, android video player, Plex, ect... after the rip the properties of the video shows no audio. The bluray does play just fine with a player and with the same drive I use MakeMKV with via VLC.
Are you sure you have both the video and audio tracks selected when ripping?shockracer wrote: Tue Jul 08, 2025 5:27 am VLC, android video player, Plex, ect... after the rip the properties of the video shows no audio. The bluray does play just fine with a player and with the same drive I use MakeMKV with via VLC.
shockracer
Oh course.... I've used this software since 2018. Mostly I've never had issues and never had one like this. When complete, the file is Mpeg 2 if that helps.
