The Worst Of Yucko The Clown no audio
shockracer
#1 Post by shockracer » Tue Jul 08, 2025 3:56 am
I get successful rips for video but the file always has no audio. It says audio is DD Dolby Digital - Stereo in the drop down before starting the process. When it successfully finishes it has no audio.
Thanks In advance.
Re: The Worst Of Yucko The Clown no audio
#2 Post by MartyMcNuts » Tue Jul 08, 2025 3:58 am
shockracer wrote: Tue Jul 08, 2025 3:56 am I get successful rips for video but the file always has no audio. It says audio is DD Dolby Digital - Stereo in the drop down before starting the process. When it successfully finishes it has no audio.
Thanks In advance.
What are you playing it with? You may have a missing audio codec. Try VLC or MPC-HC (included with the K-Lite Mega Codec pack).
shockracer
#3 Post by shockracer » Tue Jul 08, 2025 5:27 am
VLC, android video player, Plex, ect... after the rip the properties of the video shows no audio. The bluray does play just fine with a player and with the same drive I use MakeMKV with via VLC.
#4 Post by MartyMcNuts » Tue Jul 08, 2025 6:49 am
shockracer wrote: Tue Jul 08, 2025 5:27 am VLC, android video player, Plex, ect... after the rip the properties of the video shows no audio. The bluray does play just fine with a player and with the same drive I use MakeMKV with via VLC.
Are you sure you have both the video and audio tracks selected when ripping?
shockracer
#5 Post by shockracer » Wed Jul 09, 2025 5:37 am
Oh course.... I've used this software since 2018. Mostly I've never had issues and never had one like this. When complete, the file is Mpeg 2 if that helps.
