Star Trek: The Original Series Blu-ray - Season 1
dakota
Post by dakota »
I noticed that one of the episodes does not show on the list, so I can't save it. I cleaned the disc and there is no scratches or marks on it.
Star Trek: The Original Series Blu-ray - Season 1 Disc 7 -- S01E26 - Errand of Mercy
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
DEBUG: Code 0 at HLwqGX8,d;6NyUM%+:213131134
File 00000.mpls (angle 1) was added as title #0
File 00000.mpls (angle 2) was added as title #1
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '61440'
DEBUG: Code 100864261 at A%oe?*<o<t0n{T~IVR:213131502
DEBUG: Code 100864261 at 6^fi2-Z3=v]MXm2[[7@q:213134768
DEBUG: Code 0 at su*ZMu+::z<Dimc0):213132721
DEBUG: Code 1 at su*ZMu+::z<Dimc0):29400071
DEBUG: Code 1 at -RB@\N n@p=CV-8}:121262578
DEBUG: Code 0 at so0'RHGOgu[^5A/:213138494
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:29381878
Title #00001.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '61440'
DEBUG: Code 100865282 at A%oe?*<o<t0n{T~IVR:213131502
Failed to add angle #2 for title #1
File 00002.mpls (angle 1) was added as title #2
File 00002.mpls (angle 2) was added as title #3
File 00003.mpls (angle 1) was added as title #4
File 00003.mpls (angle 2) was added as title #5
File 00009.mpls was added as title #6
Title #00017.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00036.m2ts was added as title #7
File 00037.m2ts was added as title #8
Title #00160.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00161.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00164.m2ts was added as title #9
Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00186.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00024.m2ts was added as title #10
File 00025.m2ts was added as title #11
File 00026.m2ts was added as title #12
Title #00027.m2ts was skipped
File 00028.m2ts was added as title #13
File 00029.m2ts was added as title #14
Title #00030.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00097.m2ts was added as title #15
Title #00119.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 108 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Re: Star Trek: The Original Series Blu-ray - Season 1
The optical drive is still struggling to read the disc. Perhaps a second cleaning will help.
