Rhino just released a 4-BR set and none of them appear to be in the database yet. Here are the dump files:
https://www.dropbox.com/scl/fo/1140d2gl ... gusrj&dl=0
(Wasn't able to upload to this forum due to "attachment limit reached" error.)
Blu-ray dump: Ramones In Atmos (4 BR)
irateouthaul
- Contact:
Re: Blu-ray dump: Ramones In Atmos (4 BR)
The lack of this 4-disc Blu-ray set means that the database is incomplete, potentially misleading users looking for this particular release or all Ramones releases in a particular format.
All 4 of these have records added in the latest KeyDB release. I just checked.robbl wrote: ↑Mon Jul 07, 2025 6:36 pmRhino just released a 4-BR set and none of them appear to be in the database yet. Here are the dump files:
I still can't open these discs. Internet Access is enabled. Is there something else I need to do? Thank you
Did you download the latest KeyDB database and extract it to your MakeMKV data folder?
No, sorry. This is the first disc that I haven't been able to open. Now I have two with De La Soul. Sounds like that one is being added.
Where do I download the new file and how do I add it? Was just searching for this in the forum and couldn't find a post on how to do this.
Thank you
Thank you
I downloaded the latest keydb file from http://fvonline-db.bplaced.net/
I extracted that file and added it to my user directory where MAKEMKV stores its dump files. I renamed that file KEYDB.cfg
I can now open the discs
