AACS v82 Blu-ray Disc dump submission - another Japanese music Blu-ray
GenericUsername555
Post by GenericUsername555 »
Hi all,
I can't decrypt the following disc:
<I tried to add the dump file, but I received the error message "Sorry, the board attachment quota has been reached.">
<I will post it when this quote issue has been resolved>
<I have emailed it for now with a link to this forum post>
Along with my previous Blu-ray failure (posted on 30 June), this is another recent music Blu-ray from Japan. I note that quite a few recent dump submissions are for Japanese Blu-rays. Not sure if there's any meaning to this, other than Japan got a brand new set of keys.
As always, thanks in advance!
GenericUsername555
Re: AACS v82 Blu-ray Disc dump submission - another Japanese music Blu-ray
Hey SamuraiHL,
Thanks for the fast reply and the link.
Can you explain this in a little more detail how to use the information in the post you linked?
That post you linked to is for ripping UHD (my failure is with a Blu-ray).
That post also explains about KeyDB Helper, which is Windows Only (I'm ripping on a mac).
Thanks and apologies for the newbie questions!
Post by SamuriHL »
Since you're on a Mac you won't be able to use my tool directly. My tool works for both blu-ray and UHD, however. If you were on Windows, and a Windows VM under Parallels works fine for my tool, you could follow the instructions to add a device key to your keydb.cfg that allows you to add your own keydb entries for your discs.
GenericUsername555
Thanks for this clear explanation.
I don't run Parallels, so I'll wait for the keydb to be updated.
Post by SamuriHL »
Well it's not going to be unless you provide a link to the dump file. You should also email it to the svq email address so that it can be added to makemkv's hashkey database as well.
To be clear trying to attach it to the forum is unlikely to work right now. You have to host it somewhere and post a link.
GenericUsername555
Hi again,
Thanks for the advice.
I've already emailed both dump files to svq@makemkv.com.
One was emailed on 15 June, the other on 6 July.
The first dump file is also available for download on the forum here: viewtopic.php?f=8&t=38349
