MysticWizard wrote: Sat May 10, 2025 2:12 pm
Back when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Also if it is possible, will I lose the capability to write 100GB M-Disks?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: E115/ID71
I was hoping I could get some help with my new optical drive. When inserting a DVD I can play it on my laptop running Linux Mint, but MakeMKV is simply stuck "Loading...". Looking at the debug logs it says "No SDF v098: ASUS_BW-16D1H-U_A205_212012011818_[serial]", so I figured I probably have to flash the drive. I have tried running sdftool dump, sdftool flash and flashing using makemkvcon, but it every time the process is stuck with 100% CPU usage and no output in the terminal. Any ideas?
[Edit]: Downgraded to MakeMKV 1.17.6 and was able to successfully flash.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: [serial]
Firmware date: 2120-12-01 18:18
Bus encryption flags: 1F
OS device name: J:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: E116/ID71
I wanted to sent PM directly to Coopervid since I've been informed that this it the person I should ask for help, but unfortunately I don't have possibility to send PM to anyone.
I would be grateful if you could help me with flashing my drive!
Also - one more question: do the firmware update changes something when it comes to burning Blu-ray discs? I remember that it was an issue (probably for LG drives?) that after an update burning would be impossible. How does it look like with my drive?
OS device name: J:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: \Device\CdRom2
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 78
Firmware version: ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Hey Cooper, much love, seems to have worked, but I'm seeing _lower_ write speeds on the drive now (used to average 6x-9x and s now staying around 3,9x. The drive also isn't reporting as a UHD capable drive in the program, all of the UHD options remain unticked.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Post Makemkv info with an UHD in the drive. Pioneer UHD ripping is 4x max. That's normal.
Post Makemkv info with an UHD in the drive. Pioneer UHD ripping is 4x max. That's normal. DID YOU REBOOT?
Rebooting does not fix the issue, and drive is indeed having serious issues after flashing with the exact instructions. It's failing to copy any disc, showing as ' disconnected' multiple times, which makes MakeMKV skip files. I don't currently have UHD discs needing ripping, so I'm using regular disks.
OS device name: K:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number:
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
LibreDrive is enabled, but it isn't working correctly it seems.
Such a thing has never been reported before. Is this a drive in an USB enclosure? If yes you need to remove power AND USB. Otherwise the drive electronics is still powered by the USB connection.
These errors can also originate if the drive doesn't get enough power. Maybe with the new firmware it needs more power.
Coopervid wrote: Sun Jul 06, 2025 12:05 pm
Oh I'm assuming it's a skill issue on my end. I powered it down and removed USB as stated in the guide.
Maybe it's just a different enough platform that it doesn't work that well. I've also looked at BDRFlash options and tried a few after I first saw the issue. Reducing peak power mode doesn't seem to help much, so I doubt it's a power issue.
It's inconsistent on different discs and fails different files even in multiple runs of the same disc.
I suppose for all successful flashes someone has to fail. No hard feelings, I'll reflash this to original firmware.
I have the exact same model, with the USB 3 ASUS enclosure. Worked perfectly.
I did a complete shutdown, including my laptop, and then a restart.
I have currently ripped 13 of my UHD discs and no errors or anything.
What’s you computer setup?
I have a ASUS laptop with Core i5, 32GB mem, Win11, USB3.2 connection.
