Cannot write blu ray after decoding
charlie62
#1 Post by charlie62 » Thu Jun 19, 2025 10:42 pm
When I upgraded from windows 7 to the latest version I found I couldn’t write to hard drive or disc. If I had known this would happen it would never have been done. Can you tell me the reason it was changed.
Re: Cannot write blu ray after decoding
#2 Post by Billycar11 » Fri Jun 20, 2025 5:26 pm
Nah that's not a thing
What exactly are you trying to do?
charlie62
#3 Post by charlie62 » Fri Jun 20, 2025 6:22 pm
The program still works ok but as soon it changes to playback there is a whole new section telling you why there is no matching soundtrack how you arrive at this point I have no idea.anyone have any clue as to what is happening.
#4 Post by Coopervid » Fri Jun 20, 2025 8:34 pm
You are providing only bits and pieces and therefore nobody will figure out the nature of your problem(s).
charlie62
#5 Post by charlie62 » Fri Jun 20, 2025 10:11 pm
The very last page on MakeMKV is not the page it should be instead of the normal one there is a page stating there is no soundtrack available for the file. I’m sorry if this not clear but is what I’m seeing thanks
#6 Post by dcoke22 » Tue Jun 24, 2025 1:02 pm
MakeMKV does not play videos. Are you trying to use Windows Media Player with a .mkv file? Windows Media Player won't play DTS audio tracks by default. You have a download a codec pack.
charlie62
#7 Post by charlie62 » Thu Jul 03, 2025 12:25 pm
I seem to have got everyone confused which is not my purpose,anyhoo I must say now this not something I am comfortable with. After using makemkv to unscramble you are left with the file which you can send
into a file folder but at the moment when the file is written it tells me there is no sound on the file
I have recently changed from windows 10 to latest version of windows not sure if this has any bearing but would be grateful for any useful feedback
I have been using this,programme for years without any problems
Thank you in anticipation
Charlie
#8 Post by dcoke22 » Thu Jul 03, 2025 12:48 pm
Perhaps you can post a screen shot of what you're seeing?
charlie62
#9 Post by charlie62 » Thu Jul 03, 2025 8:38 pm
We can't play the audio for THE LAST STARFIGHTER - 4K UHD.
Its encoded in 7 format which isn't supported. You can still watch the video.
Learn more about codecs | Send feedback
01:40:28
This is a copy of screen
Charlie
#10 Post by Billycar11 » Fri Jul 04, 2025 4:00 am
try vlc
charlie62
#11 Post by charlie62 » Sun Jul 06, 2025 2:04 pm
Well don’t I feel stupid it was hiding here all the time. Mind you I think is time to give this up as it’s all to complicated for me.Hopefully you won’t have to be bothered with me again.
#12 Post by Billycar11 » Sun Jul 06, 2025 2:39 pm
No ones bothered
We like helping people with stuff we know about.
You have to learn somehow no need to be discouraged
