Asus BW-16D1HT wont read CD, but reads DVD and BLURAY
neverasusagane
Post by neverasusagane »
Hi
As topic states
An Asus BW-16D1HT firmware 3.0 bought long time ago but it hardly ever gets used. I've burnt less than 10 discs in total and disc-read for maybe 15 hours of use total.
Today I had reasons to read/write CDR disc, but found that it wouldn't accept empty disc "no disc", I then proceeded trying other CDR and factory cd's, but none worked.
I went over to try DVDs and BLURAY discs, and they all seem to work fine.
I then went as far as bringing a CDR I know I did burn with this same device, and that CD works to this day in my cars cd player, but my Asus BW-16D1HT still won't read it.
I've seen some topics where the device stops reading blurays, or dvd's but not cd's.
I tried to disassemble the device to see if the laser lense was dirty, but I couldn't get my head around of how to disassemble it to get to the laser optics without breaking it. I know it's diffrent laser wavelength for diffrent type of media, but arent they all placed in the same optics, so if it was dirty to the point it can't read I should have problem reading any media?
Looking forward for answer
Re: Asus BW-16D1HT wont read CD, but reads DVD and BLURAY
There's usually two sets of optics. One is for CDs and DVDs and the other is for blu-rays and UHDs. For most people, when one of the lasers stops working, it'll work for CDs/DVDs and not blu-ray/UHD or vice versa.
MakeMKV won't read CDs. You have to use other software to read a CD.
MSIVST
Post by MSIVST »
I had a similar issue and wanted to chime-in ...
In Sept of 2025, I purchased a used Asus BW-16D1HT (manufactured Sept 2024) from eBay that came with stock 3.11 firmware (as it left the factory - confirmed by chatting with ASUS Support).
I flashed it to 3.10MK right away, and was copying BR/UHD discs without issue.
Recently, I came accross some old CDs/DVDs that I wanted to put on a media center PC, so put them in the drive to be copied ...
None of them worked! It seems red laser media would not be recognised on this drive. :cry:
Digging into the firmware's and logging the outputs - It seems the drive spins and focuses, then measures the light reflected back - That measurement must spike above a fixed threshold before the firmware declares a disc present - Red media never spikes, and therefor never reports a disc. Bluray media spikes no problem.
I tested factory 3.11, stock 3.10, MK 3.10, and OmniDrive 3.02 - all fail identically.
The spike is anologue and produced by the controller/opto hardware from the drive - The firmware has zero writes to it, and therefor cannot be tweaked or changed.
Failure points could be:
(a) red/IR laser diode emission degraded or dead (from aging/ESD/shock),
(b) contamination/damage on the red IR lens path (although still did not work after cleaning),
(c) red focus/flex or photodetector return failure.
I just found it odd that a drive is failing at less than two years old ...
If i figure anything else about it I will report back :wink:
