"Copy Protection Key Exchange Failure" Error while ripping UHD discs
parag14
#1 Post by parag14 » Sat Jul 05, 2025 10:15 pm
I have an LG BP50NB40 drive flashed to the BU400N 1.03 firmware. I have been ripping discs in this drive successfully, but when I put in a Hobbs and Shaw UHD disc today (with an AACS v72 encryption), I got an error message:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Subsequently, any UHD disc I put in, regardless of AACS encryption version, stalls with that error while trying to read the disc. I am on MakeMKV version 1.18.1, and this is the disc and drive information as reported by MakeMKV:
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 81
Firmware version: 1.00
Disc Information
Label: HOBBS_AND_SHAW
Timestamp: 2019-09-05 19:02:11
Protection: AACS2.0/C v72
Data capacity: 88.96 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
I do have a log generated if needed, please let me know if there is a fix for this error. I can supply more information if needed too!
Re: "Copy Protection Key Exchange Failure" Error while ripping UHD discs
#2 Post by Billycar11 » Sun Jul 06, 2025 12:52 pm
Likely a power error use a higher powered USB port or get high powered USB hub 35+ watts
parag14
#3 Post by parag14 » Sun Jul 06, 2025 7:26 pm
Billycar11 wrote: Sun Jul 06, 2025 12:52 pm Likely a power error use a higher powered USB port or get high powered USB hub 35+ watts
I have been using this drive with 2 USB 3.0 ports for the past year and was able to rip UHD discs in that time frame, so I don't think that is an issue. Also, since I posted this issue, I installed a trial of DVDFab and it was able to rip the disc, but MakeMKV is still giving me the same errors. I can rip Blu-ray discs fine though, it's just all the UHD discs that are giving me this error, even ones that I have successfully ripped before with the exact same setup.
#4 Post by Billycar11 » Sun Jul 06, 2025 10:53 pm
parag14 wrote: Sun Jul 06, 2025 7:26 pm
Show the full log copy paste it no attachments
parag14
#5 Post by parag14 » Mon Jul 07, 2025 3:31 pm
Billycar11 wrote: Sun Jul 06, 2025 10:53 pm
This is the full log in MakeMKV when I insert the disc, resulting in the failure to read it.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Saved AACS dump file as C:\Users\Parag/.MakeMKV/MKB20_v72_Fast_and_Furious_Presents-_Hobbs_and_Shaw_5077.tgz
#6 Post by Billycar11 » Mon Jul 07, 2025 7:48 pm
Are you using a VM?
Like I said this normally happens from low power but can also be caused by
Vms
USB cases not passing through libredrive commands
Low power
Libredrive sdf not downloaded try downloading it manually from guide below
parag14
#7 Post by parag14 » Tue Jul 08, 2025 3:31 am
Billycar11 wrote: Mon Jul 07, 2025 7:48 pm Are you using a VM?
Vms
Low power
No I am not using a VM, this is on bare metal Windows. However, I tried to read the disc again just now, and after getting a "Downloading latest HK" message in the log, I am able to read the UHD discs now! I changed absolutely nothing about my setup, so I am not sure what was downloaded to make it work.
mmmkv
#8 Post by mmmkv » Sat Oct 25, 2025 1:24 am
Just wanted to add to this, in case it helps anyone coming from a search, that usage within a VM can work but it apparently depends on the Windows version used.
I had been using MakeMKV in a Windows 10 VirtualBox VM and passing through the drive enclosure via USB passthrough (USB 3.0 controller option in VirtualBox), however after switching to a Windows 11 VM with the identical settings MakeMKV reported the same errors as the OP.
So I then switched back to the Windows 10 VM and it worked without any issue again. So for whatever reason Windows 11 VMs have passthrough issues.
Another user a few years ago also encountered passthrough issues in a W11 VM, in their case using Proxmox as the hypervisor.
