When I rip a 4K UHD blu-ray in makemkv, does the mkv file actually have HDR? For example, the picture appears exactly the same in VLC player if HDR is enabled or not in Windows. When I enable HDR in Windows, I can see the change in Windows. Plus, my display briefly shows the signal has changed to HDR mode. However, there is no difference when playing a mkv file in VLC.
MKV Files and HDR
Re: MKV Files and HDR
If you look at the .mkv file with MediaInfo, the video section will list if the file has Dolby Vision and/or HDR10. For example, here's a movie with only HDR10:
and here's an example with both:
I don't really use Windows or VLC so I can't really make suggestions about them.
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 57 min
Bit rate : 50.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.256
Stream size : 41.7 GiB (93%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1376 cd/m2
Maximum Frame-Average Light Level : 731 cd/m2
Original source medium : Blu-rayCode: Select all
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Duration : 1 h 47 min
Bit rate : 100 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.504
Stream size : 75.2 GiB (95%)
Language : English
Default : No
Forced : No
Maximum Content Light Level : 7130 cd/m2
Maximum Frame-Average Light Level : 545 cd/m2
Original source medium : Blu-rayI don't really use Windows or VLC so I can't really make suggestions about them.
leosantare
Okay, well hopefully someone can help with Windows and VLC.
leosantare
Why isnt there a difference if hdr is enabled in windows or not when playing a mkv in vlc?
Ezatoka
I don't know for sure, but maybe VLC automatically issues some tonemapping if it finds a HDR source with a non-HDR display.
leosantare
I'm not sure what you mean by that. I know my display is not in HDR unless I enable it in Windows. Like I said, there is no difference in the picture if HDR is enabled in Windows. I understand VLC supports HDR and dcoke22 confirmed that mkv files contain HDR.
Mr. Red
You could try MPC-HC with MPC Video Renderer instead of VLC.
smol_birb
Windows will have the option to enable HDR, even if the display doesn't support HDR. Does your display support HDR?leosantare wrote: Tue May 06, 2025 12:39 am I'm not sure what you mean by that. I know my display is not in HDR unless I enable it in Windows. Like I said, there is no difference in the picture if HDR is enabled in Windows. I understand VLC supports HDR and dcoke22 confirmed that mkv files contain HDR.
Mutato
MPC-HC player with madVR Renderer and you need display with HDR support, check hardware specifications, user manual.
leosantare
When I had a display that did not support HDR, I could not enable HDR in Windows. Now, that I have a display that supports HDR, I can enable HDR in Windows.
Okay, I will try MPC-HC with madVR.
Thank you,
Thank you,
