I used a software called "Recovery Toolbox for CD Free" to copy the Blu-Ray to my HDD, to get around errors.
I then used MAKEMKV and the BackUp option ( I did NOT check the Decrypt Video Files option)
I let it run until I saw the first m2ts file being copied. I hit the Eject button, then the "hand" to Cancel.
It's been running for 1:50:00 so far, stuck at this message:
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 3172497408, attempting to work around
It says only 2 seconds remaining, for the last hour + now. I cancelled and got this:
Error 'Internal error - Operation was cancelled (135)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3172503552'
Failed to save title 0 to file C:/Video/After Earth - Blu-ray™ (Mastered in 4K)/After Earth - Blu-ray™ (Mastered in 4K)_t00.mkv
0 titles saved, 1 failed
I'm out of ideas for this one.
HELP NEEDED - How to RIP from files copied to hard drive
v65animal
Re: HELP NEEDED - How to RIP from files copied to hard drive
"Get around errors"?
Errors in reading the original are going to be errors in the copy, too.
v65animal
Yes, but it completes instead of failing like MakeMKV. As others have noted, they can play disc on the same system, but MakeMKV won't skip the error.
The objective of MakeMKV is to give you an "exact copy" of the video on the disk. If there are errors on the disk, then what is read is not what is supposed to be there.
Player software that reads directly from disks assume there will be errors, and silently (as much as possible) skip over them. But they aren't that tolerant when reading from your hard drive. "Recovery Toolbox" isn't trying for an exact copy. If you play what it recovered, your player will probably get a bit haywire when it hits the part of the transport stream where the original error happened.
Frankly, if the disk gives errors even after being cleaned, it should go back for replacement.
v65animal
Yes, that would be nice to just get a replacement if they had warranties on Blu-Rays. I didn't just buy this, so no receipt, etc to return it.
v65animal
A long time ago, as a kid, my Aunt had what was called a Laser Disc player. She had Star Wars and copied it to VHS for me. During the scene where the sand people attack Luke, it stuttered. (likely a disc scratch) That showed up on the VHS as well, but the rest of the movie was fine.
I was hoping to get the same result, the disc has a scratch, but I can watch it. I'd just like to copy it to my PLEX server instead of pulling out the Blu-Ray player. If it has a bad spot, or misses a few seconds, so be it.
Thanks,
Sam
Thanks,
Sam
sigidi
Maybe somebody should update that error message then.... since it is still quite confusing
SimplyLearning
I have encountered this error and couldn't find a specific thread for this as indicated in the error message URL, it provides no such link to a thread thus very misleading and frustrating. After a lot of searching and rewording my search I came across this particular thread which was discussing just this issue. Have specific instructions never been provided after all of these years on how to do this?
The message implies to simply ensure MakeMKV is not open, then copy the disc contents, so if using Windows, I assume load teh disc, open File Explorer, navigate to the disc in the drive, select all of the folders visible from the disc drive and copy them to your PC then. Then what, what is it specifically we are supposed to do to for lack of a better word to trick MakeMKV into seeing these copied folders as the disc so that you can then either go ahead as normal and use either the backup feature or rip directly to mkv? In my instance I received the error during the use of the backup feature, using a Blu-ray and it was the actual movie m2ts file that the error was encountered thus not backed up/copied to destination.
SimplyLearning
Further to my post above, I was successfully able to copy all files from my disk to my PC via Windows File Explorer, no errors were reported. Out of curiosity I simply copied the 2 files MakeMKV did not copy due to error from the location I easily manually copied from the disc into the folder MakeMKV created when it was performing the backup and then I tried opening the two m2ts files using VLC and neither will play. VLC will play all of the other files from the STREAM folder that MakeMKV successfully "backed up" but will not play these 2. What is the trick to making these files playable?SimplyLearning wrote: Sun Jul 06, 2025 2:11 am Hello,
The standard advice when a rip fails is to gently clean the disc and try again.SimplyLearning wrote: Sun Jul 06, 2025 8:47 pmFurther to my post above, I was successfully able to copy all files from my disk to my PC via Windows File Explorer, no errors were reported. Out of curiosity I simply copied the 2 files MakeMKV did not copy due to error from the location I easily manually copied from the disc into the folder MakeMKV created when it was performing the backup and then I tried opening the two m2ts files using VLC and neither will play. VLC will play all of the other files from the STREAM folder that MakeMKV successfully "backed up" but will not play these 2. What is the trick to making these files playable?SimplyLearning wrote: Sun Jul 06, 2025 2:11 am Hello,
SimplyLearning
Thanks for advice however unfortunately that did not work. Actually tried that for all of my discs where I ran into this issue but still MakeMKV would not copy the file(s) even though I can always manually (via Windows File Explorer) copy the entire Blu-ray contents from the disc drive locally to the hard drive and never run into an issue and I can see the file(s) MakeMKV has issues with are copied in their entirely. Very frustrating seeing the files can be copied but I don't know how to decrypt them locally afterwards so that I can place them with the rest of the BD files MakeMKV was able to successfully rip from each disc.dcoke22 wrote: Fri Jul 11, 2025 8:49 pmThe standard advice when a rip fails is to gently clean the disc and try again.SimplyLearning wrote: Sun Jul 06, 2025 8:47 pmFurther to my post above, I was successfully able to copy all files from my disk to my PC via Windows File Explorer, no errors were reported. Out of curiosity I simply copied the 2 files MakeMKV did not copy due to error from the location I easily manually copied from the disc into the folder MakeMKV created when it was performing the backup and then I tried opening the two m2ts files using VLC and neither will play. VLC will play all of the other files from the STREAM folder that MakeMKV successfully "backed up" but will not play these 2. What is the trick to making these files playable?SimplyLearning wrote: Sun Jul 06, 2025 2:11 am Hello,
One of the things MakeMKV does is it uses the content hash table that's part of the blu-ray specification to verify that what the optical drive reads is correct. If what was read is incorrect, MakeMKV retries reading the same spot until either the read is correct or the retry limit is reached.
When you copy files from the disc using Windows Explorer, none of this extra checking with the content hash table is done and mostly likely what is copied is incorrect. So, even if you could use the files Windows Explorer copied, they probably wouldn't work.
Rojma
If I understand correctly what you did, the two files you copied using Windows Explorer are still encrypted which is why they don't play.
