Read Errors While Ripping Criterion 4K Seven Samurai – Fails Midway with “L-EC UNCORRECTABLE ERROR”
tiberio
Post by tiberio »
Hi everyone! I’m having trouble ripping the Criterion 4K UHD Blu-ray of Seven Samurai using MakeMKV v1.18.1 on macOS (Apple Silicon). I’m using an LG BU40N drive in LibreDrive mode.
I’ve tried so far restarting the computer, reconnecting the drive and downloading and placing the latest KEYDB.cfg file in ~/Library/MakeMKV/ as suggested in another thread but it still fails... MakeMKV takes a while to decrypt the disc and does show some errors during that phase which is uncommon for me, but it seems to eventually move forward and start saving the title.
However, around one hour into the MKV conversion, the process fails with multiple read errors and ends without saving the file.
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.04 MO8LC2E4052d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=FA108BB7DA63)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.04 MO8LC2E4052' at offset '33361887232'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.04 MO8LC2E4052' at offset '33361889280'
Failed to load content hash table, unable to verify integrity of M2TS files.
Title #00004.mpls has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.mpls was added as title #0
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Family Cloud/Filmes/Seven Samurai/4k
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '31994542080'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '31994542080'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '31994542080'
Failed to save title 0 to file /Volumes/Family Cloud/Filmes/Seven Samurai/4k/SEVEN SAMURAI_t00.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Is this a sign of a bad disc or could it still be a software or drive compatibility issue? I can play it just fine in my player, and I tried other discs and they all worked fine in MakeMKV, just this one has this errors. Would greatly appreciate any help or suggestions.
Thanks in advance!
Re: Read Errors While Ripping Criterion 4K Seven Samurai – Fails Midway with “L-EC UNCORRECTABLE ERROR”
tiberio wrote:
Sat Jul 05, 2025 3:10 pm
Thanks in advance!
It could be. Please clean the disc before attempting to rip it again. It doesn't matter if it is brand new or looks pristine, just give it a clean!
