Massive visual glitches but no errors logged
holtzman
Post by holtzman »
I am experiencing massive, consistent visual glitches with certain BDs, but I do not see any errors logged in the output during/after processing, so I'm not sure what the issue is. I've cleaned the disks and they are free of scratches (some are brand new).
Please help me figure out what's wrong!
Visual glitch example:
I have had issues with all of these:
Interstellar
Dune - part two
Chronicle
Spiderman - homecoming
Spiderman - far from home
I am using a Verbatim 43888 from Amazon that I flashed, info below:
Product: BD-RE BU40N
Revision: 1.03
Serial number: ...
Highest AACS version: 68
Firmware version: 1.03
Example output for Dune - part two:
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Using Java runtime from C:\Program Files\Java\jre1.8.0_451\bin\java.exe
Title #00000.mpls has length of 12 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00003.mpls has length of 135 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00068.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00059.mpls has length of 5 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00058.mpls has length of 7 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00060.mpls has length of 23 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00061.mpls has length of 31 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00063.mpls has length of 51 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00064.mpls has length of 9 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00065.mpls has length of 17 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00066.mpls has length of 7 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00067.mpls has length of 341 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00077.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00078.mpls has length of 4 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00079.mpls has length of 4 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00050.mpls has length of 30 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00051.mpls has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00441.mpls has length of 291 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00442.mpls has length of 701 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00443.mpls has length of 384 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00444.mpls has length of 231 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00445.mpls has length of 563 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00446.mpls has length of 453 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00447.mpls has length of 460 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00448.mpls has length of 779 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00087.mpls has length of 135 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00000.m2ts has length of 12 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00001.m2ts has length of 135 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00008.m2ts has length of 31 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00009.m2ts has length of 51 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00010.m2ts has length of 9 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00011.m2ts has length of 17 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00013.m2ts has length of 341 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00049.m2ts has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00055.m2ts has length of 30 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00044.m2ts has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00106.m2ts has length of 291 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00107.m2ts has length of 701 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00108.m2ts has length of 384 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00109.m2ts has length of 231 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00110.m2ts has length of 563 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00111.m2ts has length of 453 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00112.m2ts has length of 460 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00113.m2ts has length of 779 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/dholt/OneDrive/Documents/homelab/dvd rips using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:flac.mmcp.xml'
AV sync issue in stream 6 at 0:00:00 : Forced subtitles track #6 turned out to be empty and was removed from output file
1 titles saved
Re: Massive visual glitches but no errors logged
holtzman wrote: Sat Jul 05, 2025 8:44 pm I am experiencing massive, consistent visual glitches with certain BDs, but I do not see any errors logged in the output during/after processing, so I'm not sure what the issue is. I've cleaned the disks and they are free of scratches (some are brand new).
Interstellar
Dune - part two
Chronicle
Revision: 1.03
Serial number: ...
1 titles saved
There are no issues in the log you provided.
What are you playing the generated MKV file with??
holtzman
Post by holtzman »
I have been using the default media players on win10 "Movies & TV" and win11 "Media Player" on two different systems with two different BD drives, both with no success for these titles. Your reply prompted me to check with VLC media player...which appears to work for at least a couple of those titles i listed.
Is this expected behavior? Should I always use VLC?
win11 Media Player visual glitch: https://imgur.com/a/d4NUmaV
holtzman wrote: Sun Jul 06, 2025 1:43 pm I have been using the default media players on win10 "Movies & TV" and win11 "Media Player" on two different systems with two different BD drives, both with no success for these titles. Your reply prompted me to check with VLC media player...which appears to work for at least a couple of those titles i listed.
Yeah, don't use the Windows players. Use VLC, MPC-HC or any other popular players.
