Pioneer BDR-XD05TS 4k compatibility?
zittrig
Post by zittrig »
Hi, is there a flash solution for the following drive available?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 42
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Re: Pioneer BDR-XD05TS 4k compatibility?
zittrig wrote:
Sat Nov 30, 2024 9:26 pm
Revision: 3.01
Try it...
zittrig
Post by zittrig »
Finally the drive arrived!
Flashing process successful.
@Coopervid: Thanks a lot!
zittrig wrote:
Fri Dec 06, 2024 6:12 pm
You are very welcome!
gruenfron
Post by gruenfron »
Hello, I have also a BDR-XD05
Revision: 3.10
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware version: 3.10/ID34
What could I do to make 4k backups?
Thanks in advance :)
gruenfron wrote:
Fri Jan 17, 2025 12:50 pm
Revision: 3.10
PM sent.
Yethidran
Post by Yethidran »
Attached below is the webpage to download the "Drive Utility" for settings once you have "Flashed" your XD05 to a XD06.
Cheers!
"DO NOT DOWNLOAD THE FIRMWARE UPDATE LINK!!"
JUST DOWNLOAD THE "UTILITY"
gruenfron
Post by gruenfron »
Coopervid wrote:
Sat Jan 18, 2025 12:28 pm
PM sent.
Thanks a lot, it worked, you are a gem :D
analogkid
Post by analogkid »
Hi!
What do I have to do to make the XD05TS 4k compatible?
4wheels
Post by 4wheels »
apologies for the necro, but just so I understand, it is possible to flash a BD-RW BDR-XD05 to an XD06 for 4K UHD compatibility?
Asking because I have this drive, and it has served me well up to this point, but I just bought some UHD movies, and it isn't reading any of them. I would appreciate some help.
Thanks.
4wheels wrote:
Sat Jul 05, 2025 4:17 pm
Thanks.
You guys need to post your Makemkv info.
4wheels
Post by 4wheels »
Sorry, I'm new at this... What info do I need to post? I'm on macOS if that matters. Here's the stuff from the main MakeMKV window
Revision: 3.01
Serial number: ...
Highest AACS version: 76
4wheels wrote:
Sun Jul 06, 2025 2:50 am
Revision: 3.01
Serial number: ...
PM sent. You need a Windows PC or a good VM.
