I've seen a lot of posts for MKV 82 titles lately. For blu-rays, you CAN handle these titles yourself until MakeMKV is updated to handle them for you. If you are on Windows, you can simply use my tool and follow the directions in this post:
viewtopic.php?f=12&t=16883&p=166510#p166510
Once it's set up, you just use the Disc Info button on any new disc you have, and a keydb entry will be added for you and the keydb.cfg will automatically be copied to your MakeMKV data directory. It DOES require some work to set it up. My tool does not include any device or processing keys that are required to decrypt titles. But someone posted an MKB 82 device key on doom9 and I link to that post and explain what you need to do with it to make it work with my tool.
Hopefully this post helps more people. I'll have a new version of my tool coming out in the next few days or so but the process will remain the same.
How to handle MKB 82 titles...
Re: How to handle MKB 82 titles...
So I made it even easier to use in my latest version. Check out the instructions and it should be fairly straight forward to configure. It only has to be set up once, then you're good to go.
Sound advice but please still ensure you continue to email the tgz dump files to svq@makemkv.com so the key can be added to MakeMKV's internal hashed keys database.
