Pioneer BDR-UD03 UHD possibility
Orange_Chicken
Re: Pioneer BDR-UD03 UHD possibility
Post by Orange_Chicken » Sat Jul 05, 2025 5:41 am
Hi! Just bought a verbatim with a BDR-UD03, could I get the flash? (MakeMKV info attached)
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 66
Drive platform: RS8511
Firmware version: 1.14
u5921a
Post by u5921a » Sat Jul 05, 2025 11:01 am
I've got the following drive and would be grateful for info on how to enable it to read uhd discs.
Revision: 1.14
Serial number: ..............
Post by Billycar11 » Sat Jul 05, 2025 11:06 am
Revision: 1.14
Yeah send me that drive info in an email see below
myLGdied
Post by myLGdied » Mon Jul 07, 2025 11:26 pm
WH16NS40 kicked the bucket. Could I get some help cooper?
OS device name: G:
Revision: 1.14
Serial number:
Highest AACS version: 81
Post by Coopervid » Tue Jul 08, 2025 9:19 am
OS device name: G:
Revision: 1.14
Serial number:
PM sent.
harold1967
Post by harold1967 » Tue Jul 08, 2025 6:00 pm
Got a new drive, really like to allow READING uhd with this one as well. Can I use same FW as with BDR-UD03?
New drive:
OS device name: E:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: QLDL125473WL
Highest AACS version: 77
Drive platform: RS8A10
myLGdied
Post by myLGdied » Tue Jul 08, 2025 6:33 pm
PM sent.
Thanks for the assistance. Confirmed with the 4K that killed my LG!
Post by Coopervid » Tue Jul 08, 2025 9:45 pm
New drive:
OS device name: E:
Revision: 1.14
This should work as is.
harold1967
Post by harold1967 » Wed Jul 09, 2025 6:15 am
New drive:
OS device name: E:
Revision: 1.14
It doesn't like the same disk the BDR-UD03 has no issues with:
Long list...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom3'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom3'
Saved AACS dump file as C:\Users\harol/.MakeMKV/MKB20_v61_<name removed>_505B.tgz
This morning the drive shows like below, without flashing it. Pretty sure I didn't use the tool yesterday, so what is going on?
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO6P4G90905
Post by Billycar11 » Wed Jul 09, 2025 6:22 am
OS device name: E:
Revision: 1.05
That's a completely different drive and it's not flashed
harold1967
Post by harold1967 » Wed Jul 09, 2025 6:29 am
OS device name: E:
Revision: 1.05
But its exactly the same drive I send the info for yesterday. I've read the Verbatim 43889 comes in 2 flavours, with Pioneer and LG drives.. Can this be the issue? Am I getting crazy?
Post by MartyMcNuts » Wed Jul 09, 2025 7:07 am
OS device name: E:
Revision: 1.05
That is a different drive to the first one you posted. The serial numbers are different. One is a Pioneer, the other a LG.
harold1967
Post by harold1967 » Wed Jul 09, 2025 7:47 am
Its physically the same drive, certainly not trying to mess with you. First time I connected I copied info and it showed as Pioneer BDR-UD04. (this was right after disconnecting a Pioneer UD03). A day later the drive showed as an LG. Somehow the recognition was either tricked or interpretation changed. The only thing that happened was a reboot of my PC. I was under the impression I bought a Pioneer drive, but instead got the LG version. Little bit of google also explained if "Super Multibit" and "Blu Ray Disk" logos are at the front of the Verbatim 43889, you received the LG. Pioneer front is blank. Is this drive still any good? Can I flash this to DE_LG_BU40N_1.03_MK?
Post by Coopervid » Wed Jul 09, 2025 9:42 am
Yes the LG Verbatim can / must be flashed BU40 1.03 MK. If you want to make your Pioneer UD03 UHD capable please post its Makemkv info.
Weird story btw.
harold1967
Post by harold1967 » Wed Jul 09, 2025 10:29 am
Weird story btw.
Think something was stuck, which reboot sorted.
You already assisted me with the UD03!
Thanks for your help! appreciated!
